Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Speakers cutting out?? help please
Author Thread: Speakers cutting out?? help please
Username: Noob101
Taylorsville, Utah
Post Number: 134
My speakers have been turning off since i installed them they work fine on lower levels but if i turn it up at about half-way they'll work for about 3-10 min. and then they'll turn off until i turn it back down towards the lowest volume levels there running off of my stock head-unit. At first i thought it was a charging problem but when they last turned off i looked back at my amp to see if the green power light was on and it was still on. Thanks for any help.
Username: Stateprop486
PA
Post Number: 93
ur amp settings may be too high.
Username: Kpa2727
Post Number: 859
yea ur clipping them back the amps gains down.
Username: Nd4spd18
Northwest PA
Post Number: 5752
Did you set the gain right. Sounds like the gain is too high or the amp is going into thermal protection.
Username: Noob101
Taylorsville, Utah
Post Number: 135
How do i know if the amp gain is right? the gain is very low and bass boost is off should i turn the gain all the way down as well then? and see if that fixes it?
Username: Surferdude9371
Admiting your an a$$ho...
Post Number: 516
http://www.subwoofertools.com/forum/setgain.asp
this should help ya
Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Speakers cutting out?? help please [ « Previous ] [ Next » ]
