Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Ongoin electrical prob
Author Thread: Ongoin electrical prob
Username: Surferdude9371
Admiting your an a$$ho...
Post Number: 505
ive been thinkin besides the sub which is lower rms the only things ive changed in my setup is new hu which sux (jensen but old one was a sony) and added an amp for my door speakers its only like 300 rms could either of these be my prob and if so how to test. for the amp if i unplug the rca wires is that sufficient? thnx in advance Patrick
Username: Denali_on_22s
The kids like my rhyme...
Post Number: 3693
maybe you need to replace your battery under the hood.
Post Number: 3694
or a bad alternator in that case...
Username: Adddisorder
Palm Beach, Florida
Post Number: 5825
whats the problem, low voltage?
Post Number: 511
did that already but thnx ive checked grounds made sure the powers makin it back to back bat
Post Number: 512
ya my gain and sub r turned way down and i still cant turn volume up without it burnin up. i ran the same amp with my solo x and had no prob
Post Number: 513
how do i test my alt?
Username: Nd4spd18
Northwest PA
Post Number: 5750
whats the problem?
Post Number: 515
i cant turn the gain or sub up without it fallin below 12v and i used same amp with my solo x no prob and it draws more watts
Username: Nd4spd18
Northwest PA
Post Number: 5759
Alternator or battery is bad maybe
Post Number: 517
bats r brand new how do i test alt? its puttin out right volts that mean its ok?
Post Number: 3702
go to autozone and they will test it for you. if not try your local car dealer
Post Number: 518
ok thnx man. if thats not the prob could the hu have anything to do with it?
Post Number: 3704
i mean if it's just a voltage problem i would think that your HU is fine...
Post Number: 519
what bout door speaker amp could that b a prob and would unplugin rca wires allow me to test that?
Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Ongoin electrical prob [ « Previous ] [ Next » ]
