Thread: 15" Type R |
Silver Member Username: Somedonniedude
Illinois
United States
Post Number: 798 Registered: May-07
| Posted on Thursday, January 24, 2008 - 05:56 pm: |
How much can a 15" type R handle daily? The rms is 750, so I was thinking 1000w? Do these sound good sealed, as compared to the 12"s? |
Illinois
United States
Post Number: 799 Registered: May-07
| Posted on Thursday, January 24, 2008 - 07:00 pm: |
Bump |
Silver Member Username: Bonhamd
Northern,
Michigan
Post Number: 101 Registered: Nov-07
| Posted on Thursday, January 24, 2008 - 07:07 pm: |
I think the 15 would be fine on 1000. as far as SQ I haven't heard the 15s; only the 12s |
Platinum Member Username: Bestmankind
RD 1000.1D with SI MAG...
Post Number: 17321 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 07:26 pm: |
1000wrms should be good but don't over do it. i know someone who had a pair of 15s and messed it up with some serious power. he was playing a song with some low bass and the rubber surrounds just came off the basket. the 15 type Rs sound good btw. gets really loud too. |
Illinois
United States
Post Number: 800 Registered: May-07
| Posted on Thursday, January 24, 2008 - 07:36 pm: |
Think they do good sealed? Or should they be ported? |
Post Number: 17322 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 07:39 pm: |
type Rs work well both ported and sealed. i like sealed subs so i had them sealed. however i did have them ported at one time and it still sounded clean while getting extremely loud. |
Illinois
United States
Post Number: 801 Registered: May-07
| Posted on Thursday, January 24, 2008 - 07:59 pm: |
Awsome. I wasnt sure if they were like the 12's or not, but I guess they are. |
Silver Member Username: M0nkeyman692
Post Number: 493 Registered: Feb-07
| Posted on Thursday, January 24, 2008 - 09:04 pm: |
i really like the 15's the one i saw was in a ported box and was given 800rms and it sounded great. it was very clean while still being loud. the only thing i didnt like was the person who did it didnt put one of those clip wire holders in the box,(the ones you clip the speaker wire into and it goes through the other side to the subs.) he just drilled a hole in the box and ran the wire through. so you can hear air rushing. but besides that i loved the setup and the sub. |
