Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Alpine Type-R SWR-1242D Or Kicker Sol...
Author Thread: Alpine Type-R SWR-1242D Or Kicker Solo-Baric S12L7
Username: Aldrich12
I'm planning to buy a subwoofer for my car. I've narrowed down my choices to these two. which do you think is better?
Username: Drant19
DUB-C, TX
Post Number: 277
what are you looking for? SQ, SPL, a mix of both?
the L7 is a SPL sub that has crappy sound quality. so if u want it to be just loud, then thats your sub.
however if you want to maintain the sound quality, the type-r would be your sub.
whats your budget? maybe theres a better sub for you needs...
Username: Ska
Post Number: 198
get the R because if the right set up, the R can and will sound AMAZINGE
And im not a fan of Alpine at all ;)
Username: Aldrich12
Thanks for your responses. I'm looking for a mix of both SPL and SQ. Budget is around 400 max for a pair. Is there something better than those 2?
Username: Somedonniedude
Illinois
United States
Post Number: 797
Do you have an amp already? What kind? What kind of vehicle is it going into?
Username: Nd4spd18
Northwest PA
Post Number: 5748
L7s don't just have bad SQ, the build quality sucks big time
Get the Type R
Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Alpine Type-R SWR-1242D Or Kicker Sol... [ « Previous ] [ Next » ]
