Thread: Seen these before?? |
Bronze Member Username: Fryedman
Perth,
Wa
Australia
Post Number: 13 Registered: Jan-08
| Posted on Thursday, January 24, 2008 - 01:05 pm: |
Perth,
Wa
Australia
Post Number: 14 Registered: Jan-08
| Posted on Thursday, January 24, 2008 - 01:17 pm: |
Hi all, these speakers are 21mm x 10mm, sorry dont speak inches. the magnet is 12mm. these speakers have no markings at all, so im trying to find the maker to find out what OHM they are and what wattage, I wired them up to an amp and they worked but the 150watt on each speaker didnt really do much. look forward to finding out what they are, any clues would be great.. |
Bronze Member Username: Exige
Post Number: 72 Registered: Nov-07
| Posted on Thursday, January 24, 2008 - 04:47 pm: |
no clue on what they are. however, if you use a DMM and test the coil of the driver, you can find out the load (ohms). for the cm-in conversion...it comes out to 8.2" x 3.9"....that's one hell of a weird sized cone and it really doesnt look like it from the picture...maybe you measured incorrectly? or maybe your measurements are not of the cone but of something else? let me know. |
