Thread: Amp for a Q |
Silver Member Username: Kingandsons07
Lincoln,
Nebraska
U.S.A
Post Number: 589 Registered: Feb-07
| Posted on Thursday, January 24, 2008 - 09:25 am: |
well i got the Q it hits hard but i know it can get louder i got a us amps xt-2000d on it i tryd a kicker sx1250.1 on it. it hit harder but it didn't sound good it wasn't picking up the low's like late night tip |
Platinum Member Username: Bestmankind
RD 1000.1D with SI MAG...
Post Number: 17280 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 01:01 pm: |
so you are saying the kicker hit harder than the us amp but the us amp sounded better? or is the other way around? |
Silver Member Username: Ska
Post Number: 195 Registered: Jan-08
| Posted on Thursday, January 24, 2008 - 01:36 pm: |
i think the kicker just wasn't tuned correctly |
Lincoln,
Nebraska
U.S.A
Post Number: 593 Registered: Feb-07
| Posted on Thursday, January 24, 2008 - 01:55 pm: |
you got it chad so i got the us back on it. i was thinking about a zx1500 but the ssf is preset to 15 i think thats a good amp. i was thinking about putting a saz-3000d on it till i get the money for the dd's or two saz-1500 but the would cost me more in the long run so will i be ok with the saz-3000 on it |
Post Number: 17288 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 02:49 pm: |
well quentin told me the other day he messed with it long enough to know how to tune. i assume you are running 2 subs. i think the saz3000 is cool. but i have never seen a saz3000 lol. |
Silver Member Username: Kingtutus
Lincoln,
Nebraska
U.s.a
Post Number: 108 Registered: Dec-07
| Posted on Thursday, January 24, 2008 - 03:24 pm: |
no only one FI Q. |
Post Number: 17289 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 03:30 pm: |
why do you want so much power for 1 Q? is it dual 1ohm? |
Lincoln,
Nebraska
U.s.a
Post Number: 109 Registered: Dec-07
| Posted on Thursday, January 24, 2008 - 03:42 pm: |
i don't know y he wont to put so much power on it no dual 2 ohm |
Post Number: 17291 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 03:44 pm: |
so he only needs an amp that does 1000wrms at 1ohm for that sub. don't get greedy. lol. |
Lincoln,
Nebraska
U.s.a
Post Number: 110 Registered: Dec-07
| Posted on Thursday, January 24, 2008 - 03:50 pm: |
his us amps dose 1000wrms. he need like 1500wrms. the Q has the bp on it |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 5739 Registered: Jul-06
| Posted on Thursday, January 24, 2008 - 03:52 pm: |
No you don't NEED 1500w. Thats pushing it even with the BP. 1000w is what that sub is designed for........ |
Post Number: 17295 Registered: Oct-05
ohhhhhh ok. |
Lincoln,
Nebraska
U.s.a
Post Number: 111 Registered: Dec-07
| Posted on Thursday, January 24, 2008 - 04:03 pm: |
the rating for the FI Q with BP is 1200wrms-1500wrms |
Northwest PA
Post Number: 5741 Registered: Jul-06
| Posted on Thursday, January 24, 2008 - 04:30 pm: |
So they say...... those subs have been known to have issues like tinsel slap, especially when powered over 1000w |
Lincoln,
Nebraska
U.s.a
Post Number: 112 Registered: Dec-07
| Posted on Thursday, January 24, 2008 - 04:36 pm: |
they have fixed it |
Post Number: 17298 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 04:38 pm: |
i still say you are getting greedy with the power. |
Gold Member Username: Naledge503
Http://www.LowDownForu...
Post Number: 2833 Registered: Jun-06
| Posted on Thursday, January 24, 2008 - 06:06 pm: |
The XT-2000D only does 800 rms @ 1ohm |
Gold Member Username: Andrew571
Stillwater/Edmond,
Oklahoma
Post Number: 1393 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 06:57 pm: |
Get yourself a T10001BD .... You can't go wrong with that nice of an amp plus all of them are usually birthsheeted around 1400+. I powered Qs with a T10001BD without the BP Option... I gave it 1526 watts @ 1ohm... The Q didnt sweat. I say throw 2k @ it. It wont hurt unless ur a complete idiot with it. |
Northwest PA
Post Number: 5751 Registered: Jul-06
| Posted on Thursday, January 24, 2008 - 07:30 pm: |
" they have fixed it " right........ I'll believe that when we stop seeing subs with tinsel slap issues |
Silver Member Username: Marcooo
Post Number: 267 Registered: Mar-07
| Posted on Thursday, January 24, 2008 - 09:27 pm: |
1500w rms on it daily used reasonably will be fine for it, BP option or not. That's the common consensus on SSA and I've got a Fi Q with BP. Only have ~900 on it atm, not for long though. BP option or not I'd be real careful giving it more than 1500w rms. |
Lincoln,
Nebraska
U.s.a
Post Number: 114 Registered: Dec-07
| Posted on Thursday, January 24, 2008 - 11:07 pm: |
Quentin wonts to get saz-3000d for the 2 DD3518's. but he needs a different amp for his Q so y go buy two amps when i will be cheaper to get the one and set the gain down. then he don't have to get a another amp when he up grades |
Gold Member Username: Jkidder
Gunshine ,
State
Flawda
Post Number: 3100 Registered: Nov-05
| Posted on Thursday, January 24, 2008 - 11:13 pm: |
sx1250 is def. enough for it. perfect amp for it. thats an SQ amp and puts out 1300+ |
Lincoln,
Nebraska
U.s.a
Post Number: 115 Registered: Dec-07
| Posted on Thursday, January 24, 2008 - 11:17 pm: |
we cant get it to sound good, we even took it to a ex-kicker worker to set it. he didn't no how to set it so we called Chad lee and he help a little then we set it some more but the us amps was still louder. |
