Thread: Good amp to match Infinity 1250w |
Bronze Member Username: Coreyh6987
J-Town,
NC
Post Number: 40 Registered: Feb-05
| Posted on Thursday, January 24, 2008 - 07:06 am: |
I was thinking about putting my system back in my car and I'm trying to find an amp to match my 2 Infinity 1250w's. I did have an Xtant a6001, which was perfect for the subs.... How well do you guys think a Apline MRP-M450 would match these subs?? or some other amps that arent insanely expensive.... Thanks Alot! |
Gold Member Username: Tejcurrent
Post Number: 1026 Registered: Apr-07
| Posted on Thursday, January 24, 2008 - 07:21 am: |
^That alpine amp is pretty expensive for the power it puts out. I'm not familiar with the sub, what is the rms power you're looking for? (I'm stabbing in the dark at around 600?) |
J-Town,
NC
Post Number: 41 Registered: Feb-05
| Posted on Thursday, January 24, 2008 - 07:30 am: |
I can get the amp for around $150 at crutchfield.com... Yea the subs put together is 600 RMS. They are 4 ohm and I was going to wire them into 2 ohms since the amp puts out 400w RMS x 1 @ 2 ohms. I also seen the MRP-M650 which is perfect but I wasnt wanting to spend much since my car was broken into a few weeks back.... |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 5734 Registered: Jul-06
| Posted on Thursday, January 24, 2008 - 03:33 pm: |
Alpine makes very nice amps |
