Thread: Who could make me this?! |
Bronze Member Username: Jladam415
Post Number: 24 Registered: May-07
| Posted on Thursday, January 24, 2008 - 01:54 am: |
http://mobile.jlaudio.com/gallery/detail.php?vehicle_id=2128 also how much, for a 12w7, would that even be enough airspace to be loud at all? |
Post Number: 25 Registered: May-07
| Posted on Thursday, January 24, 2008 - 02:44 am: |
or this box, i really need something http://mobile.jlaudio.com/graphics/ENC/W7HOWedge_Tech.jpg?0.31802739703368643 |
Gold Member Username: Mike11202
DD9515G VFL 200.1 = : ,
Sewell, NJ
US
Post Number: 1237 Registered: Nov-06
| Posted on Thursday, January 24, 2008 - 06:37 am: |
I have a 12w7 in HO wedge, how much are you looking to pay? |
Silver Member Username: Mesodumm
Tri-City,
Az
Usa
Post Number: 273 Registered: Apr-07
| Posted on Thursday, January 24, 2008 - 09:58 am: |
I do them in fglass but pointing up like that is dumb! |
Tri-City,
Az
Usa
Post Number: 274 Registered: Apr-07
| Posted on Thursday, January 24, 2008 - 09:59 am: |
I do them in fglass but pointing up like that is dumb! i'll find picks and put on my myspace in little it is www.myspace.com/uroc97tj |
Tri-City,
Az
Usa
Post Number: 275 Registered: Apr-07
| Posted on Thursday, January 24, 2008 - 10:00 am: |
sorry 4 repost |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 6589 Registered: Jul-06
| Posted on Thursday, January 24, 2008 - 10:06 am: |
You can contact a local JL dealer and they'll be able to give you a price and can probably build that box to spec. You can also contact Woodlaw Cabinetry or Fischer(Fisher?) Customs and get quotes from either of these guys. They both do great work. |
Post Number: 26 Registered: May-07
| Posted on Thursday, January 24, 2008 - 02:14 pm: |
yes, i used fisher last time, and probably will again... I am looking for JUST The box, let me know if you want to let that go and i will buy it (how muhc?) as far as the fiberglass, how much would that cost? and firing which way would be best and loudest? befor i have a 10w7 in a 1.5cu sitting on the back seat, sub up, port foreward and that was loud. what do you guys recoomend, with/without taking out the back seat |
