Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Subwoofer box dimensions
Author Thread: Subwoofer box dimensions
Username: Pbplayer05
Carroll, Iowa
Post Number: 263
how do i get dimensions for a 3.5 cubic box with it at 32 hz
Carroll, Iowa
Post Number: 264
help plz its for 2 12s
Carroll, Iowa
Post Number: 265
Carroll, Iowa
Post Number: 266
abyone
Username: Cblaze
Rock island, Tenesssee
Us
Post Number: 1547
http://www.subwoofertools.com/forum/ported-box.asp
Carroll, Iowa
Post Number: 267
how do i figure out the dimension that i will need though thats were im lost
Username: Cblaze
Us
Post Number: 1549
what u mean,do u mean will it fit in your vehicle??
Carroll, Iowa
Post Number: 268
no it asks for the xterior dimensions and that wat i dont know how to get i know its suppose to be 3.5 cubes at 32 hertz but thats it
Carroll, Iowa
Post Number: 269
or do i just put wat i can fit in it
Username: Cblaze
Us
Post Number: 1554
enter in how ever wide and tall u want the box,and it will do the rest.u enter how many cubic ft u want on there.and it gives u demensions.notice u dont enter the depth u want.that is because it tells u the depth u need to get that amount of airspace
Carroll, Iowa
Post Number: 270
is it an acurate program
Username: Phil_salisbury
Post Number: 500
Not all if any enclosure design programs account for some details when calculating the enclosure's final specifications, so be mindful of what is and is not part of the design that you need to account for.
Carroll, Iowa
Post Number: 271
as in what
Post Number: 501
Each program is different as to what elements they do and don't account for, but, if you looking for a list of what the elements are, here it is:
Net Volume - That which only the subwoofer requires.
Subwoofer Displacement - Volume of the subwoofer
Port Volume - Volume of the Port - round, square, slot port size.
Port Wall Volume - MDF Parts that make up port or tube.
Bracing Volume - Material used brace the interior of the enclosure.
Carroll, Iowa
Post Number: 272
so what would u say is missing that i need to account for
Post Number: 502
OK, if you use the program per the link posted, it covers all the elements with the exception of BRACING.
If your not going to use bracing, then don't sweat it.
Username: Cblaze
Us
Post Number: 1555
justin it must be accurate,thats what like half the ppl on here use to get box designs.
Carroll, Iowa
Post Number: 274
awesome sounds good to me wats a double baffle though
Post Number: 505
Chris,
There's no true accurate enclosure design program, if there were one, then there wouldn't be or the need to have so many different calculator's all over the internet.
Off hand I would say there are at the very least 10 to 15 enclosure design programs/calculators on the net right now and there are only a few that actually provide a " CUT LIST/Parts List " to make the job easier which is why they are " popular ".
Carroll, Iowa
Post Number: 275
Username: Nyyfan13
15 MAG
Post Number: 8082
A double baffle is just using 2 sheets of MDF on top of each other to make it stronger. Instead of having the sheet be 3/4", it would be an 1.5".
Carroll, Iowa
Post Number: 276
do u need to do that
Carroll, Iowa
Post Number: 277
Username: Drant19
DUB-C, TX
Post Number: 279
you dont NEED to if you have good bracing
Username: Cblaze
Us
Post Number: 1556
ive always wondered wat happens if ya dont brace it or double up thew wood with high powered subs?does the box flex like crazy?
Carroll, Iowa
Post Number: 278
well will i need to double baffle or brace it or should i be ok
Carroll, Iowa
Post Number: 280
Username: Shortysetnies
Rock Vegas, NC
US
Post Number: 1772
It all depends. What sub are you running, how much power? for the average system, no double baffle but a little bracing always helps...
Carroll, Iowa
Post Number: 282
well it will be 2 12 bms and a usampos md2d
Rock Vegas, NC
US
Post Number: 1775
I would defiantly do bracing and a double baffle will never hurt but I wouldnt say it was nessicary in your case
Carroll, Iowa
Post Number: 283
well would bracing change the freaquency or anything and how do u do it also the doublew baffle is just another front panel then right
Username: Stevil
Post Number: 37
Okay.. does this program take the port displacement into consideration?
Carroll, Iowa
Post Number: 284
http://www.subwoofertools.com/forum/ported-box.asp?Ew=29&Eh=18&Dia=6&Xmax=16&Vd= 1.75&NumW=2&Vb=3.5&Fb=32&Qts=&Vas=&Fs=&CE=1.5
thats wat it came up with
Carroll, Iowa
Post Number: 286
Username: Cblaze
Us
Post Number: 1562
if thats what it came up with build it
Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Subwoofer box dimensions [ « Previous ] [ Next » ]
