Thread: 4inch speaker |
New member Username: Ashokdurai
Chennai,
TN
India
Post Number: 1 Registered: Jan-08
| Posted on Wednesday, January 23, 2008 - 07:41 pm: |
Hi, i am in look out for some high end speaker probably component package. but the restiction is that.. my car which is Fiat Uno has company provided housing both in front and rear which allows only 4 inch / 10cm. and i want it especially placed inside tht. can any one suggest anything max in an 4inch system? |
Bronze Member Username: Exige
Post Number: 67 Registered: Nov-07
| Posted on Wednesday, January 23, 2008 - 09:55 pm: |
if you throw a sub in the back, you'll be fine. CDT's ES-42i component set is one high-end option that will fit your 4" requirements. and don't worry, at many places you'll see a retail of $680. it can be found for much lower. |
Post Number: 68 Registered: Nov-07
| Posted on Wednesday, January 23, 2008 - 09:56 pm: |
here's a link for you: http://www.buycdt.com/es42i.htm |
Silver Member Username: Mrsq
California
Post Number: 173 Registered: May-06
| Posted on Thursday, January 24, 2008 - 04:56 am: |
now is this cdt thing really worth for 600 bucks, man i mean how good is it for that price, because really you can get a ts-c720prs component set and way cheaper but awesome sq |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 5730 Registered: Jul-06
| Posted on Thursday, January 24, 2008 - 12:50 pm: |
Thats retail price you can get them for a lot less |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 276 Registered: Aug-07
| Posted on Thursday, January 24, 2008 - 01:03 pm: |
ts-c720prs are a 6.5"speaker... i dont know why that was brought up |
California
Post Number: 174 Registered: May-06
| Posted on Thursday, January 24, 2008 - 01:30 pm: |
oh didnt read it right, he wants only 4inch, try QSD210 4inch comps by MBquart |
Post Number: 69 Registered: Nov-07
| Posted on Thursday, January 24, 2008 - 04:40 pm: |
there's a reason i said that it can be found for much lower than retail. how bout lets not bash the price, and instead read the posts, mmk? |
Chennai,
TN
India
Post Number: 2 Registered: Jan-08
| Posted on Thursday, January 24, 2008 - 05:42 pm: |
thks a lot frnds.. i will chk it out. |
Chennai,
TN
India
Post Number: 3 Registered: Jan-08
| Posted on Thursday, January 24, 2008 - 05:43 pm: |
how far focal is good to CDT? |
Post Number: 73 Registered: Nov-07
| Posted on Thursday, January 24, 2008 - 06:14 pm: |
please reference another current thread here in the forum called Focal vs. CDT. Focal and CDT are both great, high-end brands...but they are different in sound. Check out that thread for more info. |
Chennai,
TN
India
Post Number: 4 Registered: Jan-08
| Posted on Monday, January 28, 2008 - 01:13 am: |
thks.. i will chk but can some one say the diff of wht is component system and co-axial system? sry if tht was an too lame question |
Northwest PA
Post Number: 5838 Registered: Jul-06
| Posted on Monday, January 28, 2008 - 01:23 am: |
I believe thats explained in the other thread also |
Post Number: 83 Registered: Nov-07
| Posted on Monday, January 28, 2008 - 01:32 am: |
yep both are explained....please reference the thread: http://forum.ecoustics.com/bbs/messages/4/438908.html |
