Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > 2 12 fully loaded fi btl
Author Thread: 2 12 fully loaded fi btl
Username: Blkgt94
Pittsburgh, P.A.
if i get 2 12 fully loaded btl's can i run 4 kicker zx 1500 for them if i get the dual 2ohm coils an run a kicker zx 1500 off each coil? an is a 3.8 cube tuned to 38 hz good? an is my powering good to run all this 200 amp alt. big 3 2nd battery an its all 0/1 then its 4g off the 2nd battery to the amps?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2054
You could potentially do that. I think that would be difficult with the charging system you listed tho.
Username: Drant19
DUB-C, TX
Post Number: 271
definately need a bigger alt!
Username: Blkgt94
Pittsburgh, P.A.
couldnt get no bigger alt. that was the biggest that i could get that bolted on
Username: Marcooo
Post Number: 260
Get dual alts then.
Username: Blkgt94
Pittsburgh, P.A.
no room its a 2.5 probe/mazda mtor just tolk 4 ours to unstall the old one an re install the new one tight fit how about 1 18 btl an to kicker zx 1500 wilthat be fine ut i still wnna now how i can un the 2 12s with 4
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2055
You would be fine doing the one 18. You could even do a zx2500 on one with that charging if you wanted.
Username: Blkgt94
Pittsburgh, P.A.
Post Number: 7
2 kicker zx 1500 put out more than the 2500
1 2500= 2,800-3,000
2 1500= 3,300-3,500
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2057
I can do math. You asked about one 18 BTL on a zx1500. I suggested, if you're doing that single sub, to do a zx2500 instead. You are correct that two 1500s are more power.
Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > 2 12 fully loaded fi btl [ « Previous ] [ Next » ]
