Thread: HELP '99 GTPw/Bose, installing deck,amp,subs |
New member Username: 99gtpsprchd
Post Number: 2 Registered: Jan-08
| Posted on Wednesday, January 23, 2008 - 05:16 pm: |
I have a '99 Grand Prix GTP with a Bose sound system. I bought an Alpine deck(Model # IDA-X001) , a Sony Xplod 1000Watt 2/1 channel amp(Model # XM-2165GTX) , a 12" Sony Xplod 1200Watt sub with a box, Rockford Fosgate 4awg amp install kit w/a 100amp fuse, Install Edge adjustable line output converter(2-60Watts)(Model IEC AULOC) and i would like to install all of it in my car myself because they want to charge me $280 to have it done professionally at Best Buy because the Bose system makes it more difficult. I would like to know how to install these things and make it so it goes with the Bose sound system. PLEASE help me if you can! |
Relevant Product Info
Post Number: 3 Registered: Jan-08
| Posted on Wednesday, January 23, 2008 - 05:20 pm: |
I also have a stock trunk mounted 12 CD changer that I would like to have added to the new Alpine deck aswell if its possible/easy. Thanks! |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 6668 Registered: Jul-06
| Posted on Tuesday, January 29, 2008 - 09:26 am: |
In all honesty...if your vehicle has the Bose system installed in it and you planned on upgrading with the things you mentioned above it's not worth it. You'll ruin the clean sound that you more than likely have right now. Stick with the Bose setup. If you really want to change it... just wire everything separate from the way it's wired now. Run all new speaker wires and leave the stock amplifier that is in there now installed. If I were you I'd leave all the stock wiring in place so you can go back to the Bose setup when you decided to sell the car. |
Post Number:...
Post Number: 6669 Registered: Jul-06
| Posted on Tuesday, January 29, 2008 - 09:28 am: |
Oh and if you need that little bit of extra bass just install your line out converter and run that mono amplifier with your 12'' sub. Stick with the stock HU, especially if it has any special features such as steering wheel controls or heat/door chimes/alarm. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 5877 Registered: Jul-06
| Posted on Tuesday, January 29, 2008 - 03:08 pm: |
I was never impressed by most of those "premium" stock systems, monsoon, Bose, RF, etc. |
Post Number:...
Post Number: 6677 Registered: Jul-06
| Posted on Tuesday, January 29, 2008 - 03:43 pm: |
True but working around them can be a pain in the azz. Especially if you're new to doing installs. |
Post Number: 4 Registered: Jan-08
| Posted on Tuesday, January 29, 2008 - 10:54 pm: |
whats the stock HU? what does HU stand for? |
Post Number:...
Post Number: 6688 Registered: Jul-06
| Posted on Wednesday, January 30, 2008 - 03:07 pm: |
HU stands for head unit. |
