Thread: Brad Warren, M.S.....about RTA |
Platinum Member Username: Bestmankind
RD 1000.1D with SI MAG...
Post Number: 17188 Registered: Oct-05
| Posted on Wednesday, January 23, 2008 - 10:15 am: |
ok i want to know which mic i need to get and what software i need to use my laptop as a rta. any info would be great. |
Gold Member Username: Extrmndor3
Http://illuzonemu.serv...,
^^^Sick Game
Post Number: 7576 Registered: Feb-06
| Posted on Wednesday, January 23, 2008 - 10:55 am: |
http://www.trueaudio.com/rta_faq1.htm#Microphone%20Questions basic one |
Post Number: 17193 Registered: Oct-05
| Posted on Wednesday, January 23, 2008 - 12:04 pm: |
ok thanks. but if you can find me a direct link to the items from the people that sell them. also don't i need a software for my laptop? |
^^^Sick Game
Post Number: 7577 Registered: Feb-06
| Posted on Wednesday, January 23, 2008 - 12:58 pm: |
yes man... u have to buy the rta software.. the premium one.. go to that very same link or trueaudio.com and ull see it there... go to ebay... and copy the model number of the mic and the preout amplifier and buy it.. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 5701 Registered: Jul-06
| Posted on Wednesday, January 23, 2008 - 01:21 pm: |
I have TrueRTA software on my laptop http://www.trueaudio.com/rta_down.htm There is a free verion, but your can search online for the code to unlock the full version. They recommend a Behringer ECM8000 mic which is what I have. http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=Behringer+ ECM8000&category0= Then you need a preamp for the mic, and a long XLR cable to connect it. I have a Behringer UB802 mixer as a preamp, but it is more complicated than it needs to be. I've seen other people just use a cheaper/simpler preamp, I'm probably going to get one. Just look on ebay for one with 48v power. |
Post Number: 17206 Registered: Oct-05
| Posted on Wednesday, January 23, 2008 - 01:44 pm: |
alright thanks m.s. i knew i could count on you. what you think about this though. its only a 10 band but i think it could be effective and easy to carry around. http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=390-815 |
Northwest PA
Post Number: 5708 Registered: Jul-06
| Posted on Wednesday, January 23, 2008 - 02:18 pm: |
Damn that's expensive and not nearly as accurate as you could do with the mic and pc software |
Post Number: 17219 Registered: Oct-05
| Posted on Wednesday, January 23, 2008 - 02:19 pm: |
yeah i thought the price was a bit steap. but for convinience its pretty cool. ima copy you M.S. and get the mic and the mic mixer.  |
Post Number: 17220 Registered: Oct-05
| Posted on Wednesday, January 23, 2008 - 02:20 pm: |
oh and the reason for me wanting the rta is cause i will be picking up berny's audiocontrol eqx this weekend. |
Northwest PA
Post Number: 5710 Registered: Jul-06
| Posted on Wednesday, January 23, 2008 - 02:41 pm: |
Haha cool but I'd recommend just getting a simple preamp instead of the mixer....... should be easier to work with |
Post Number: 17232 Registered: Oct-05
| Posted on Wednesday, January 23, 2008 - 03:49 pm: |
ok gotcha. thanks again. once i get my sh!t tuned, it will be awesome. |
Post Number: 17287 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 02:47 pm: |
ok i am bidding on the mic right now. can you find me a decent preamp on ebay? link. |
Post Number: 17293 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 03:48 pm: |
this is the mic i am bidding on. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D290200228095&ru=http%3A%2 F%2Fsearch.ebay.com%3A80%2Fsearch%2Fsearch.dll%3Ffrom%3DR40%26_trksid%3Dm37%26sa title%3D290200228095%26category0%3D%26fvi%3D1 |
Northwest PA
Post Number: 5740 Registered: Jul-06
| Posted on Thursday, January 24, 2008 - 03:56 pm: |
Hmm I will get back to ya on that..... I haven't really looked into them even for myself yet. I just have seen before a guy with a setup similar to mine and he had one. |
Post Number: 17296 Registered: Oct-05
ok. thanks. |
Silver Member Username: Mrsq
California
Post Number: 175 Registered: May-06
| Posted on Thursday, January 24, 2008 - 04:43 pm: |
what head unit did you use the rta on M.S.? |
Northwest PA
Post Number: 5743 Registered: Jul-06
| Posted on Thursday, January 24, 2008 - 06:16 pm: |
what does a headunit have to do with the RTA? |
Post Number: 17311 Registered: Oct-05
| Posted on Thursday, January 24, 2008 - 06:18 pm: |
btw m.s. that software i download is complicating. expect me to ask you some questions when i get everything done. |
