Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Crimping
Author Thread: Crimping
Username: Kingandsons07
Lincoln, Nebraska
U.S.A
Post Number: 585
what the best way to Crimp Ring Terminals?
Username: Th3pwn3r
Post Number:...
Post Number: 6574
With a crimper. Some people crimp them on and then solder them to the terminal for extra security. Some people use a hammer.
Lincoln, Nebraska
U.S.A
Post Number: 586
ok for 1/0 were can i get a crimper?
Username: Tejcurrent
Post Number: 1020
I use a pex crimper, you'll have trouble finding a 1/0 crimper. I'd solder it after crimped like rob said- just head up the terminal back with a torch and let the solder melt into the front.
Username: Mesodumm
Tri-City, Az
Usa
Post Number: 271
Diesel mechanics use them, I got mine from Six States Supply
Username: Mesodumm
Tri-City, Az
Usa
Post Number: 272
I still run solder in the crimp.
Username: Waresgaragestereo
Fort Valley, GA
United States
Post Number: 62
I've never crimped anything that big. For 4Ga and smaller I use whats called Vice Grips.
their technical name is locking pliers.
Username: Th3pwn3r
Post Number:...
Post Number: 6575
http://www.tessco.com/products/displayProductInfo.do?sku=54536&eventPage=1
Username: Th3pwn3r
Post Number:...
Post Number: 6576
http://www.wiringproducts.com/index1.html
Hammer Style Battery Lug CrimperT-CR-990015
Designed to crimp battery lugs and terminals. One solid hammer blow and the terminal is crimped. Can also be used with a vice. Designed to crimp solderless connectors sizes 8 gauge through 4/0 gauge.-This is your best bet.
RD 1000.1D with SI MAG...
Post Number: 17187
i use a plain hammer to crimp 0 gauge stuff. it works fine for me. lol.
Username: Surferdude9371
Admiting your an a$$ho...
Post Number: 494
vice grips, hammer, then solder
Username: Mendonmafia
Post Number: 842
ive brokes 3 straignt up vices trying to crimp wires LOL. works well tho if they can handle it.
Username: Nd4spd18
Northwest PA
Post Number: 5705
LOL @ ghetto crimping......... and you don't have to spend $250 on a crimper either........
https://weldingsupply.securesites.com/cgi-bin/einstein.pl?Next::1:UNDEF: OR:04040
remove space after the :
I have one of these for 8-4/0 ga.
Username: Safe_cracker
Chicago, IL
US
Post Number: 3954
I use solder, always, never crimp then coat with Corrosion-X... Polo.
Username: Th3pwn3r
Post Number:...
Post Number: 6582
I smash the ring terminals onto the wire using my pen1s as a hammer.
Username: Southernrebel
Monroe, Louisiana
2 DD3515s, 2...
Post Number: 5850
I just use my teeth the strip and crimp 1/0ga.
Username: Bnd_rulez
Phoenix, AZ
Post Number: 1246
Thats how real men do it!
Post Number: 17228
hahahahaha
Username: Somedonniedude
Illinois
United States
Post Number: 796
Wow M.S. only $8.24? I think I'm gonna buy one.
Username: Nd4spd18
Northwest PA
Post Number: 5747
Yea....... I think it was ~$15 with shipping
Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Crimping [ « Previous ] [ Next » ]
