Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Strongest wood??
Author Thread: Strongest wood??
Username: Ska
Post Number: 136
im going to be putting a full wood sheet instead of a metal one on my back panal, im lookin at wood now on the home depot web sit these are the different woods they have listed:
Lauan Plywood
Birch Plywood
Oak Plywood
Birch Hardwood Plywood
MDF
5Ply Oak Plywood
Standard Hardwood
Lauan Hardwood Plywood
Maple Hardwood Plywood
Keep inmind this is for ONE peice of the box, so all i need is just the strongest of those, it will be covered with the carpet thats already on there so i just need to know what the best wood would be
Username: Basebalz13
Moneta, Va
Usa
Post Number: 247
i think its birch, im not 100% sure tho get some more answers
Username: Ska
Post Number: 138
i'll get more answers if ppl would say them ;-) lol
Username: Drant19
DUB-C, TX
Post Number: 232
birch...my friend made a box with birch. that b!tch is STRONG. and plus if you treat the wood, it looks badazz.
birch gets my vote
Username: Ska
Post Number: 141
ok what size should i get?1/2 or 3/4 or could i go thinner because its stronger than MDF?
Username: Surferdude9371
Admiting your an a$$ho...
Post Number: 466
depends on the sub if its a small sub 1/2 could be fine but if its big you may need to even double baffle the 3/4
Username: Ska
Post Number: 145
its going to be a treo ssi 10.44 on a kicker zx750
Post Number: 467
how much does that weigh do you know?
Username: Ska
Post Number: 149
um i think its like 15lbs
Username: Shortysetnies
Rock Vegas, NC
US
Post Number: 1730
I would just use 3/4" MDF unless you are using the wood for something else besides a box. 3/4" MDF would be plenty strong for that setup
Username: Ska
Post Number: 155
yea, i just don't want something that thick...
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5153
my pen1s
Username: Ska
Post Number: 156
i said thikness not length david ;-)
Post Number: 5154
rofl you sed strongest wood :-)
Username: Drant19
DUB-C, TX
Post Number: 237
he needs something that will stay hard after a few minutes...lol jk
Username: Ska
Post Number: 159
yea, but there has to be something in it... what good will a 3/4 by 1/4 peice of wood do me ;-)
Post Number: 472
1/2 maple for a sub that light i think would be fine i think but im no expert so id get more opinions
Username: Ska
Post Number: 163
yea i wanna go with 1/2 or maybe even 1/4... will fiberglassing around the sub hole help with stability? if so i will do that as well
Post Number: 5156
lol ill only stay hard for a few seconds then prematurely ejacu-late all over my hand before it reaches my c0ck....this is one of those to much info posts...
Username: Drant19
DUB-C, TX
Post Number: 240
^^^LMAO
wow....you just said that...nice to know someone else has that problem.
i mean what?
Username: Ska
Post Number: 164
so your like the american pie guy right? LOL
Post Number: 5157
lol broke back ecoustics?
Username: Drant19
DUB-C, TX
Post Number: 241
"lol broke back ecoustics?"
HAHAHA
new motto
Ecoustics..Boys only!
Post Number: 5160
rofl... it seems to be a trend lately doesnt it. every girl runs from ecoustics.
Username: Drant19
DUB-C, TX
Post Number: 242
girls have coodies. gross
Username: Ska
Post Number: 165
aye men Abarca TRUE FOCKIN STORY
Rock Vegas, NC
US
Post Number: 1740
Half inch would work with bracing. How big will the biggest side be?
And fiberglass wouldnt add too much strength to it. Fiberglass is strongest where it is curved/bent
Username: Ska
Post Number: 167
well im guessing ( havn't taken measurments yet) that its about 2 ft by maybe 3 feet ish? so the wood won't be very big
Username: Ska
Post Number: 178
bump
Username: Van_man
Boston South, MA
Post Number: 3276
of those listed, 5 layer oak
Rock Vegas, NC
US
Post Number: 1742
2x3 will be fine with 1/2" if you brace it. Might not need it but it wont hurt.
Username: Ska
Post Number: 186
bracing it with some fiberglass will be ok right?
Username: Safe_cracker
Chicago, IL
US
Post Number: 3962
Strongest or densest? There is a difference. Strongest is going to have to be OSB (orientated strand board) this stuff when coated with epoxy will not need bracing. My External port TCAB box was made out of that, just not as dense as MDF... Polo.
Username: Ska
Post Number: 188
i just need something that wont flex... and will minimize vibrations as much as possible
Chicago, IL
US
Post Number: 3963
OSB... Reason being it is made up of multiple layers of wood strands orientated in different patterns to overlap, then resin is added along with a healthy dose of pressure, extremely strong and no flex that is the builing material of choice for homes. Birch you will need at least a 11-13 ply for enclosures then you need bracing. Polo.
Username: Ska
Post Number: 190
Polo where would i get OSB? how thik does it have to be for no flexing?
Chicago, IL
US
Post Number: 3975
same 5/8 or 3/4" very popular material. Polo..
Username: Ska
Post Number: 199
thanks polo:-)
Username: Mrsq
California
Post Number: 182
im using nara wood as my sealed box for my 2 10 jbl
Home > Message Board > Car Audio > Subwoofers > Archive through January 26, 2008 > Strongest wood?? [ « Previous ] [ Next » ]
