Thread: Need help with speaker rms |
Bronze Member Username: Zester
Gardena ,
California
Post Number: 27 Registered: Jan-08
| Posted on Tuesday, January 22, 2008 - 02:32 am: |
if i have two speaker and each are 30 watt rms, and i want a 2channel amp to push them, can i get 50x2 at 4ohm rms amplifier, i mean will it blow up the speakers because it has 20 more watt? |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 12660 Registered: Jun-06
| Posted on Wednesday, January 23, 2008 - 07:27 pm: |
Just be ginger on the volume and light on any settings. Depending on the amp it might be overrated anyway. You're not dealing with alot of power here so the quickest way to kill any speaker is with user error. |
Bronze Member Username: Exige
Post Number: 66 Registered: Nov-07
| Posted on Wednesday, January 23, 2008 - 09:52 pm: |
^^yep you're fine as long as you dont kill the volume knob too much. 50x2 will be perfect for you |
Gardena ,
California
Post Number: 31 Registered: Jan-08
| Posted on Thursday, January 24, 2008 - 04:37 pm: |
thank you guys, now i know, ok i will have my friend install the amp today, im exited guys, thanks again |
