Thread: Im a begginer i need help!!!! |
New member Username: Mjben08
Post Number: 1 Registered: Jan-08
| Posted on Wednesday, January 16, 2008 - 10:19 pm: |
My amp want stay on when i change from radio to cd. what should i do? I hav it wired with the REM/ANT wire. Its a sony... |
Silver Member Username: Alpine97
Paramount,
California
Post Number: 266 Registered: Jan-08
| Posted on Wednesday, January 16, 2008 - 10:22 pm: |
What model? It's you remote wire. double check it. Sony HU are not very good no offense. You should get an Alpine or Pioneer. They are easy to use and they are very nice. (No problems). |
Post Number: 2 Registered: Jan-08
| Posted on Wednesday, January 16, 2008 - 10:33 pm: |
The rem wire is the same as the ant wire. do you know the right wire to connect the rem wire from the amp? Also my truck cuts off when i hit a big bump but i made sure all the wires had a good connection... |
Paramount,
California
Post Number: 273 Registered: Jan-08
| Posted on Wednesday, January 16, 2008 - 10:52 pm: |
The remote wire is blue and is not the same as the ant. if you dont have a power antenta then that wire is useless. |
Paramount,
California
Post Number: 274 Registered: Jan-08
| Posted on Wednesday, January 16, 2008 - 10:56 pm: |
My bad i thought you meant pwrantenna. Its the same wire. Most units have the same "remote" or antenna wire. Most of the time this wire is blue and can be used for both amp remotes and antennas, sometimes simultaneously. |
Paramount,
California
Post Number: 275 Registered: Jan-08
| Posted on Wednesday, January 16, 2008 - 10:57 pm: |
Either double check your wireing or it's you sony HU |
New member Username: Mostly_highs
Post Number: 8 Registered: Feb-08
| Posted on Thursday, February 14, 2008 - 11:00 pm: |
same problem blue and white stripped try that |
