Thread: Im trying to learn... |
New member Username: Ford_bronco
Post Number: 1 Registered: Jan-08
| Posted on Sunday, January 13, 2008 - 02:43 pm: |
Ok I want to buy these speakers. http://www.sonicelectronix.com/item_8815_MTX+Audio+XT693.html and buy this amp and subs. http://www.sonicelectronix.com/item_9444_Visonik+VB210PKW.html I just got lost by the RMS and Peak Power. I dont have a deck yet but I will probably be buying a alpine, I dont want to buy those speakers and blow them or there not good enough, thanks in advance! |
Post Number: 2 Registered: Jan-08
| Posted on Sunday, January 13, 2008 - 02:45 pm: |
Will I have to buy an AMP for the speakers aswell? I dont need really any bass out of them, I just wanted to no if there gunna be decent. |
Gold Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 1151 Registered: Mar-05
| Posted on Sunday, January 13, 2008 - 05:09 pm: |
Whoa.. First why don't you tell us how much money you have to spend and what kind of budget you are working with. 6x9's and Visonik both suck. |
Phoenix,
AZ
Post Number: 1152 Registered: Mar-05
| Posted on Sunday, January 13, 2008 - 05:11 pm: |
I meant what kind of budget do you have and what kind of sound you want. Like SQ/ SQL or SPL. Blonde moment. |
Post Number: 3 Registered: Jan-08
| Posted on Sunday, January 13, 2008 - 06:46 pm: |
I want the best sound for the money, What is SQ/ SQL or SPL ? I no nothing about speakers/ decks or anything electronic. Why do 6x9's suck? Have you owned Visonik? thanks. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 5411 Registered: Jul-06
| Posted on Sunday, January 13, 2008 - 07:47 pm: |
no offense but to put it bluntly, mtx = not good visonik = crap Round speakers = better than non-round Post what your max budget is and what all you need amp, subs, speakers, etc. and we can decide the best for the money......... |
Post Number: 4 Registered: Jan-08
| Posted on Sunday, January 13, 2008 - 11:20 pm: |
I dont really have a "max" budget. I think im just going to wait till I finsh rebuilding the truck then look into stereo's. |
