Home > Message Board > Car Audio > Head Units > Steering wheel controls dont work wit...
Author Thread: Steering wheel controls dont work with new head unit
Username: Bradrgilmann
Post Number: 16
I have an altima with steering wheel controls and with a new head unit the radio and gauge controls do not work. I heard there is an adapter but it is really hard to hook up. Which adapter would I need and is it easy enough to do yourself? I have hooked up systems and head units before.
Thanks
Brad
Relevant Product Info
Username: Typejl
Hopkinton, Iowa
United states
Post Number: 20
hay man same here i have done a lot of systems also
yes there is an adaptor out there and im pretty sure its self explanitory on how to hook it up
what year is ur altima
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Head Units > Steering wheel controls dont work wit... [ « Previous ] [ Next » ]
