Home > Message Board > Car Audio > Speakers > Archive through February 16, 2008 > Door speakers
Author Thread: Door speakers
Username: Deadrabit
Post Number: 90
i am going to buy all new door speakers but i don't want to go to the local audio store and get ripped off and buy something that is way over priced.
what is good? i have a 300 watt amp hooked up to the door speakers right now. bigger amp? is that amp fine?
Username: Exige
Post Number: 46
need an exact model name and number on that amp. what's your budget, and what type of sound are you going for...bright, mellow, etc.
Username: Deadrabit
Post Number: 92
i have a lot of money. i have one 18 FI BL and will have 2 in that car. so i am not sure.
what ever will sound good with my masive subs
Username: Exige
Post Number: 47
plz answer those questions specifically....unless you give us an idea on all that stuff, we can't do much to help you. for example...you say you have a lot of money. well great, so let me recommend some focal utopia be's at over 2 grand a set. see my point? need a budget. also need to know what your ears like....do you like a brighter sound, a mellower sound...crazy midbass...what do you like? and lastly, what amp do you have for your comps...it makes it really hard to recommend speakers if we dont know the exact specs on the amps. for all we know, it could be a 150wrms amp that does 75x2.....which wouldnt cut it for a lot of comps. 300 watt amp doesnt even tell me if its peak or rms rated. need model name and number.
Username: Deadrabit
Post Number: 97
ya i know what ya mean. idk if i will be much help right now cause i am just now buying the car and i don't know what kind of amp it has. ill look at let ya know.
prolly around 200 bucks or so
Username: Exige
Post Number: 49
alright well when you get that info let us know.
Home > Message Board > Car Audio > Speakers > Archive through February 16, 2008 > Door speakers [ « Previous ] [ Next » ]
