Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > JL Audio 300/4 & 500/1 Power Wiring Q...
Author Thread: JL Audio 300/4 & 500/1 Power Wiring Question
Username: Malby7
Post Number: 25
I'm planning to put both of these subs in my car with two 4 gauge wires coming from a distribution block to each of these subs (One 4ga wire each). The load will be about 100 amps. Should I run 2 gauge from my battery to my distribution block, or will 4 gauge be enough to carry the power?
Username: Malby7
Post Number: 26
I meant I'm putting both of these amps in my car!
Username: Jonathan_f
GA
Post Number: 198
4 guage would probably do it, but I'd do two guage to be safe. Better safe than sorry. Also it depends on how long the wire will be.
Username: Malby7
Post Number: 27
The wiring would be at least 10 feet long if not a little longer. It has to go from the battery of a Ford Focus to the rear seats.
GA
Post Number: 206
I'd do 2 guage just for peace of mind.
Username: Malby7
Post Number: 29
Is piece of mind worth the extra $2.00 per foot?
Username: Malby7
Post Number: 30
Is the piece of mind worth the extra $2 per foot for 2ga?
GA
Post Number: 220
That's a question you need to ask yourself. With JL amps as expensive as they are, I personally wouldn't cop out on the wire. 4 guage will definately do the job if the runs are just over 10 feet. I've seen 2 guage wiring kits online for around 50 bucks, that's remote wire, power, ground, grommets, everything you need.
Username: Jiggaman3105
im goin to tell you straight and simple...all u need is 4 ga. main power wire if its only going 10 ft. its only 100 amps, thats nuthin. im pushin a 1000/1 and a 450/4! nbow thats current draw.
Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > JL Audio 300/4 & 500/1 Power Wiring Q... [ « Previous ] [ Next » ]
