Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > MTX Amp question(Glasswolf?)
Author Thread: MTX Amp question(Glasswolf?)
Username: Calaway
Austin, TX
I am looking at a pair of Cerwin Vega104 10 inch subs at 4 ohms.
Will an MTXT8302 2-channel 300w RMS amp be ok for these? Here are the specs on the amp.
RMS Power measured at 12.5 Volts DC:
75 Watts x 2 into a 4 Ohm load
150 Watts x 2 into a 2 Ohm load
300 Watts bridged into a 4 Ohm load
Or what is an alternate med to low price range amp for these thats not a Sony?
Username: Calaway
Austin, TX
The Vegas are single coil btw.
Also looking at an Rockford Fosgate500BD mono (300 W X 1 @ 4 Ohms RMS)
and a Rockford Fosgate3002 2-chan( 300 W X 1 @ 4 Ohms Bridged RMS)
Username: Glasswolf
NorthWest, Michigan
Post Number: 3289
JBL BP600.1 will give 300wRMS to each sub
the BP300.1 would give 150w to each sub.
Username: Calaway
Austin, TX
Post Number: 8
Thanks Glasswolf, but the JBL isn't in my range. You are saying that I my 300w rms thinking for na amp is incorrect that I need at least a 600w rms mono?
Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > MTX Amp question(Glasswolf?) [ « Previous ] [ Next » ]
