Thread: Two amp problems |
New member Username: Zaggreen
Post Number: 1 Registered: May-04
| Posted on Sunday, May 30, 2004 - 02:32 am: |
I have two mtx 4202 amps and two alpine 10 inch subs. I have each amp wired to one sub. (one amp for each sub) I am running a 4 gauge wire from the battery to a distribution box, and two 8 gauge wires from the box to the amps. everything turns on just fine, but it seems as if i'm not getting enough power. when both subs are on, they are really quiet. One sub by itself is louder than the two. If i turn the gain on one amp down, the other one gets louder. how can i fix this? |
Silver Member Username: Jonathan_f
GA
Post Number: 158 Registered: May-04
| Posted on Sunday, May 30, 2004 - 02:51 am: |
Check the Polarity of the subs. They could be out of phase. |
| Posted on Monday, May 31, 2004 - 09:59 am: |
swap speakers and see if the problem follows that speaker. I had a bad speaker once that did the same thing. |
New member Username: 88retta
Farmtown,
Oh
| Posted on Monday, May 31, 2004 - 11:20 am: |
I also have a proble with hooking up a 2nd amp to my subs. I just got a 250 watt amp to hook up to my 12s just to give them some extra boost, but i dont know how to hook up the RCA's. The power, ground, and remote seem to be no problem, but i just cant figure out how to hook up the RCA's. If anybody could tell me that would be very helpfull. |
Farmtown,
Oh
Post Number: 2 Registered: May-04
| Posted on Monday, May 31, 2004 - 11:30 am: |
I also have one more question i'm hoping could get answered. If i succefully get my 2nd amp hooked up, would i be able to bride it ? my other amp is running is stereo, and my subs are 4 ohms a peice, and my other amp you cant bridge it or it will shut down after like 2 minutes, but my new amp is 2 ohm stable, so i was just wondering if that would mess anything up. |
Bronze Member Username: Cainer
Camberley,
Surrey
England
Post Number: 81 Registered: May-04
| Posted on Monday, May 31, 2004 - 11:45 am: |
you dont want stereo for 2 subs, you'l lose loads of SPL run the amp in mono if you can |
| Posted on Monday, May 31, 2004 - 01:17 pm: |
Is there really no one out there that can help me on this? I would realy appriciate any advice. any at all. |
| Posted on Monday, May 31, 2004 - 02:55 pm: |
check for voltage drop when running two amps as compared to just one. And dont be a smart *ss these people who posted advice are trying to help |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 174 Registered: Apr-04
| Posted on Monday, May 31, 2004 - 05:47 pm: |
Its probably to much current needed and not enough (from the car) to give. Get a better battery. Also check you ground. Yes, it may seem stange but use thick wire for the ground and make sure you sand paint off around the ground contact. The better attached the ground the better power you get (i speak from expeiance). |
Post Number: 3 Registered: May-04
| Posted on Tuesday, June 01, 2004 - 01:54 am: |
sorry people, i wasn't trying to be a smart a$$. i am just desperate for help. thanks for the suggestions! |
