Thread: New system |
Bronze Member Username: Kingtutus
Lincoln,
Nebraska
U.s.a
Post Number: 41 Registered: Dec-07
| Posted on Tuesday, December 25, 2007 - 09:58 am: |
i am looking in to getting 2 fi 18 q's but i need a new hu and a good amp. im think about getting jk atomic 5k is that a good idea. |
Lincoln,
Nebraska
U.s.a
Post Number: 42 Registered: Dec-07
| Posted on Tuesday, December 25, 2007 - 10:00 am: |
jk32sho's atomic |
Silver Member Username: Kingandsons07
Lincoln,
Nebraska
U.S.A
Post Number: 435 Registered: Feb-07
| Posted on Tuesday, December 25, 2007 - 10:37 am: |
do it man but don't turn the gain up to much and you will be so happy with it |
Gold Member Username: Jakeyplaysbass
ASU
Post Number: 2231 Registered: Jul-05
| Posted on Tuesday, December 25, 2007 - 11:49 am: |
do you have the charging system to run that much power? 250-300amp alternator 2+ batteries big 3 upgrade to 1/0 wire just know what your getting into before you decided to go big. |
Lincoln,
Nebraska
U.S.A
Post Number: 436 Registered: Feb-07
| Posted on Tuesday, December 25, 2007 - 11:59 am: |
he dose i'm helpin puttin stuff in his truck |
Silver Member Username: Philly306
North carolina
Post Number: 688 Registered: Apr-07
| Posted on Tuesday, December 25, 2007 - 01:08 pm: |
you are gonna need alot of space for 2 18" Qs |
Lincoln,
Nebraska
U.S.A
Post Number: 438 Registered: Feb-07
| Posted on Tuesday, December 25, 2007 - 01:44 pm: |
i'm thinking of 13-15 cuft 30Hz your going to be bangin |
New member Username: Buccaneersfan80
Post Number: 1 Registered: Dec-07
| Posted on Tuesday, December 25, 2007 - 04:19 pm: |
im looking into purchasing my first new system for my car and im stuck between what subs i should get as well as an amp, im looking at two 12 MTX Thunder 4500s or two 12 Alpine SWE-1242? and as far as amps ive been told alot of different things so im kinda confused if anyone has good advice for which of those subs are a better choice and whether or not a shouuld buy a kicker mono amp or an alpine mono amp id really appreciate it |
Lincoln,
Nebraska
U.s.a
Post Number: 43 Registered: Dec-07
| Posted on Tuesday, December 25, 2007 - 05:05 pm: |
if i was you i have heard both of them and i would go with the alpines they can handle more power then the mtx, the mtx will blow really easy if you have anything setup wrong. |
Silver Member Username: Vtouch06
Q-TowN,
PA
Post Number: 280 Registered: Nov-07
| Posted on Tuesday, December 25, 2007 - 06:55 pm: |
def dnt get MTX subs if you get alpine, get the type R's and get a kicker amp they give u the bang for your bucks and there under-rated..they usually do more rms.., usually there's good prices on ebay for them... |
Post Number: 4 Registered: Dec-07
| Posted on Tuesday, December 25, 2007 - 08:09 pm: |
thanks guyz, what kind of enclosure would you reccomend i know both ported and sealed have their own pros but if i wanted it to bring out the most bass possible would i go with a ported? |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 141 Registered: Aug-07
| Posted on Tuesday, December 25, 2007 - 08:19 pm: |
ported definately! |
Post Number: 5 Registered: Dec-07
| Posted on Tuesday, December 25, 2007 - 08:28 pm: |
thanks, i found this deal on crutchfield http://www.crutchfield.com/App/Product/Item/Main.aspx?g=208250&i=700ALPPKG6&tp=4 42 would you guys look into this or build another piece by piece on ebay, because ive heard the type e alpines arent as good so ive been looking at the type Rs like V.T. said. i also had a question what is the difference between 4ohm and 2ohm subs |
Bronze Member Username: Fred_sanford
Huntsville,
Alabama
Usa
Post Number: 73 Registered: Nov-07
| Posted on Tuesday, December 25, 2007 - 08:42 pm: |
their are better deals to be had, what budget and what kind of car do you have |
Post Number: 6 Registered: Dec-07
| Posted on Tuesday, December 25, 2007 - 09:14 pm: |
i have a 2000 nissan Pathfinder, and i'm looking to spend about 300 on subs or a little more inculding the enclosure |
Q-TowN,
PA
Post Number: 287 Registered: Nov-07
| Posted on Wednesday, December 26, 2007 - 01:27 am: |
the difference between 4ohm and 2ohms is what you wire them too, and what amp you are using...heres the wiring options... (2)Dual 2 ohms wired in parallel/series=2ohm load
(2)Dual 4 ohms wired in parallel/parallel= 1ohm load
and then just find amp that is 2ohm or 1ohm stable your choice.... I found this on ebay (2) Dual 4 ohms for $234.45 shipped...then you would need an 1ohm stable amp http://cgi.ebay.com/2-ALPINE-SWR-1242D-12-3000W-PAIR-SUBWOOFERS-TYPE-R-NEW_W0QQitemZ150198178668QQihZ005QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Or i found these (2) Dual 2 ohms $263.98 shipped...then you would need an 2ohm stable amp http://cgi.ebay.com/2-ALPINE-SWR-1222D-12-TYPE-R-SUBS-SUB-WOOFERS-3000W_W0QQitemZ170179787337QQihZ007QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Q-TowN,
PA
Post Number: 288 Registered: Nov-07
| Posted on Wednesday, December 26, 2007 - 01:28 am: |
^^for Rob Smith... |
