Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > 2 ohm rated subs
Author Thread: 2 ohm rated subs
Username: Trunkslayer
Fl
US
Post Number: 10
I have two crossfire db312d's I was looking at them the other day and noticed that they were rated from 2/ 8 ohms. I have my heart set on a one ohm config, will that damage the subs as long as I dont clip them?
Username: •cam•
BC
Post Number: 1369
The coil values are just that. They don't care what they are wired to. The amp does. I'm tired.
Username: Vtouch06
Q-TowN, PA
Post Number: 250
it all depends on the amp ur using what you wire the subs too....
A pic is worth
1000 posts!!
Post Number: 11954
Why are you tired Cam?
Username: Rellikfl
New Port Richey, FL
Post Number: 56
^Sexy Time!
Username: Vtouch06
Q-TowN, PA
Post Number: 252
he is pretending to be tired, so he could go to sleep early so he can wake up early to see santa claus in the morning lmao...
Username: Rellikfl
New Port Richey, FL
Post Number: 57
Username: Nd4spd18
Northwest PA
Post Number: 4919
What exactly does it say on the subs?
What coils they have determines what amp you need for them.
Username: •cam•
BC
Post Number: 1372
Funny. I have no idea why I was tired. I said that to cover my as$ in case what I said made no sense.
Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > 2 ohm rated subs [ « Previous ] [ Next » ]
