Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > BOX HELP
Author Thread: BOX HELP
Username: Santa_fe
02 Hyundia Santa Fe, 120.3 db not...
Post Number: 442
how many cubic feet should a box for a 15 in fi ssd be it will be tuned @ 37hz unless someone has a better freq. thanx
Username: Santa_fe
Post Number: 443
bump
Username: Vtouch06
Q-TowN, PA
Post Number: 234
www.ficaraudio.com has the specs of the 15" Fi SSD and they recommend 3-4cu ft tuned @ 33hz for ported box...
Fs: 25.9 Hz | 25.3 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.78 | 4.89
Qes: .65 | ..58
Qts: .57 | .52
Mms: 246g | 258g
Cms: 0.15mm/N | 0.15mm/N
Sd: 810cm^2 | 810cm^2
Vas: 141.3 l | 141.3 l
Spl: 87.6dB 1W/1m | 87.8dB 1W/1m
Bl: 9.3 N/A | 00.0 N/A
Xmax: 21mm
Rms: 800W
Sealed box: N/A cuft
Ported box: 3-4 cuft @ 33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.000”
Displacement: 0.17cuft
Username: Rovin
4 10 Pioneer...
Post Number: 12642
y would u want a odd no like 37hz ? - unless its ur car's peak freq ?
lower 30s should be alot more musical....
Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > BOX HELP [ « Previous ] [ Next » ]
