Home > Message Board > Car Audio > Multimedia Systems > Jensen VM9022 default code work work!...
Author Thread: Jensen VM9022 default code work work!! HELP
Username: Kc11703
we just installed my VM9022 and the default security code that comes with it will not work... what the hell?? anyone had this prroblem.. HELP.. is there a reset or something i can call????
Relevant Product Info
Username: Hansondw
Jacksonville, Fl
Usa
If you haven't gotten it taken care of yet, try entering the code backwards; worked for me.
Username: Nicolajpj
On mine it was 012345 .. Doesn't that work?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Multimedia Systems > Jensen VM9022 default code work work!... [ « Previous ] [ Next » ]
