Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > Locked out of Car :-(...
Author Thread: Locked out of Car :-(
Username: Volfenhagking1600
SSD Wangin, Shawano, Wis...
Post Number: 1104
ok so i just went out to my car and my doors are frozen shut...has this ever happened to you and how can i get my doors opened?
Thanks
Username: Nd4spd18
Northwest PA
Post Number: 4845
I live in northern PA near the NY border, in the snow belt....... this happens all the time.
Can you pull your door handle? If not chip away the ice from above/under the handle so you can pull it. Then get some de-icer fluid and spray it in the door jambs around the weather seal. Or sometimes you can just pull real hard and break it loose. Don't break your door handle though.
Username: Nickyp0219
Post Number: 244
I dont know how to get your doors open now, but for the future, use food grade silicone and put it on the rubber seal around your door, itll prevent it from freezing in the winter.
Username: Nd4spd18
Northwest PA
Post Number: 4847
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=PST&MfrPartNumber=AS242&C ategoryCode=2104
Post Number: 1105
thanks...yea it happens up here all the time too. but yesterday it was raining and 40 degrees. so i didnt think anything of it then i wake up this morning and its snowing and 40 mph wind gusts and iced everything lol
Username: Cblaze
Rock island, Tenesssee
Us
Post Number: 997
i know how to unfreeze the lock and door handle.get a big glass of very hot water from your sink,steaming hot and pour it on the door handle thats what we have always done when it was frozen shut
Username: Nd4spd18
Northwest PA
Post Number: 4852
^^^^^ real funny
Username: Cblaze
Us
Post Number: 1003
it works ms
Username: Nd4spd18
Northwest PA
Post Number: 4854
I hear thats good way to de-ice windows too
Username: Cblaze
Us
Post Number: 1004
idk i never tried that,it would prolly freeze back,but it works for your doors
Username: Carguy
Post Number: 6915
If you're going to pour hot water on the car, make sure you do it SLOWLY. If not you will crack the windows.
Username: Cblaze
Us
Post Number: 1014
couldnt u just use your defrost and a ice scraper to clear the windowshield off,its bad on a car to not let it warm up anyways
Username: Carguy
Post Number: 6919
If a rain freezes all over the car, it'll take hours before it melts it.
As an alternative, you can use a hair dryer to melt frozen keylocks/holes on the door.
Post Number: 1106
yea but when you cant get into your car how you supposeed to start it chris..
btw i poured windshield wiper fluid over the doors and they came loose :-)
Username: Cblaze
Us
Post Number: 1029
put the key in and turn it
Username: Carguy
Post Number: 6920
Chris you sound like you never had a ice storm. When it happens, there's almost 1" thick of ice all over your car. You can't even get in the car. Pouring hot water SLOWLY worked for me. However, a hot air blower/hair dryer works as well.
Username: Cblaze
Us
Post Number: 1030
oh ice storm your in that i didnt pay attention,ive been in one b4,nobody went anywhere,everythang was covered in ice no electricity for a month
Username: Somedonniedude
Illinois
United States
Post Number: 596
I usually just p1ss on my windshield...
and my door handles
Username: Marcooo
Post Number: 157
The same thing happened to me down in Appleton Jamie. I just pulled real hard lol
Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > Locked out of Car :-(... [ « Previous ] [ Next » ]
