Thread: Q15 Question |
Bronze Member Username: Rellikfl
New Port Richey,
FL
Post Number: 29 Registered: Dec-07
| Posted on Sunday, December 23, 2007 - 04:29 am: |
On there site they say its 1000RMS but whats its peak? And is the extra $40 worth the BP Power Option? |
Gold Member Username: Rideredder
Cornell,
IL
Post Number: 1244 Registered: Sep-05
| Posted on Sunday, December 23, 2007 - 04:57 am: |
Forget about peak power. If they're rated at 1000rms, then you give them 1000rms. They could handle a little more than that, but don't quote me on that. |
New Port Richey,
FL
Post Number: 30 Registered: Dec-07
| Posted on Sunday, December 23, 2007 - 04:58 am: |
ok, thnx |
Gold Member Username: Joebruce
15 AQ HD3
Post Number: 1652 Registered: May-04
| Posted on Sunday, December 23, 2007 - 05:01 am: |
You will be fine giving it 1000wrms but if you get the BP option then you should give it a lil more. I have also heard that the BP option is a waste of money but i really dont know personally. |
New Port Richey,
FL
Post Number: 31 Registered: Dec-07
| Posted on Sunday, December 23, 2007 - 05:24 am: |
Thanx TWIZTiD |
Gold Member Username: Naledge503
Http://com4.runboard.c...
Post Number: 2496 Registered: Jun-06
| Posted on Sunday, December 23, 2007 - 07:01 pm: |
Scott said, a long time ago, that he would not put more than 1300rms on a stock Q. The BP option gives better cooling and allows for better power handling and also adds an extra spider. Here's a descrition from Fi of what the BP option does. "This new option adds a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also add 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack for a little extra mechanical ability. All of these new features increase power handling from 200-500 Watts depending on the application." |
