Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > Is this my prob
Author Thread: Is this my prob
Username: Surferdude9371
Admiting your an a$$ho..., Florida
Usa
Post Number: 354
ive been talkin bout my charge prob i think this may be it? what do you think?
Usa
Post Number: 355
image/bmpUpload
Username: Nd4spd18
Northwest PA
Post Number: 4819
Thats definitely hooked up wrong. Isolator should have 3 terminals. Batt 1, Batt 2, and Alternator. The alt connects to the isolator NOT any of the batteries. Read the isolators manual.......
Username: Nd4spd18
Northwest PA
Post Number: 4820
Unless thats a relay not a isolator......
Usa
Post Number: 357
had installed but the guy is an idiot. thanks
Username: Nd4spd18
Northwest PA
Post Number: 4822
Also is all that wire good heavy gauge? It is espically critical to use 0 gauge for the alt to isolator wire. And from the isolator to audio system battery if you're running a lot of power.
Usa
Post Number: 358
yeah it is all 0 gauge
Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > Is this my prob [ « Previous ] [ Next » ]
