Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Need a good budget amp
Author Thread: Need a good budget amp
Username: Hqh17
i have 2 Pyramid 12s that can each handle 600 watts RMS and i need an amp to power them but i have a very tight budget. what is something good that i can afford?
Username: Nd4spd18
Northwest PA
Post Number: 4812
Hifonics Bxi1206d
Overrated, does about 900-1000 watts. Good enough for those subs though, and you won't find a decent amp at that power for less.
Username: Hqh17
US
how about the Boss GT-2500D? it claims 1500 watts RMS into 2 ohms. i figure for around $140 its a pretty good deal if it does close to what it says
Username: Hqh17
US
Username: Hqh17
US
my bad...
Username: Nd4spd18
Northwest PA
Post Number: 4821
Boss = crap. Does nowhere near the claimed power.
You might want to take a look at this before asking any more brand quesiotns:
http://forum.ecoustics.com/bbs/messages/34579/329117.html
Username: Cblaze
Rock island, Tenesssee
Us
Post Number: 989
get the hifonics it will be plenty loud,id trash the subs and put 2 12inch kicker cvrs on it tho
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5080
x2
I'd sell those subs and start over. You should try something cheap and awesome like RD audio lower models or DD and you'll be more than pleased
Username: Bnd_rulez
Phoenix, AZ
Post Number: 932
Yeah, those swap mart brands sure cr@p.
Username: Cblaze
Us
Post Number: 993
i say cvr cuz he sounds ike he has a small budget it and there lik 75 a piece on
www.onlinecarstereo.com
Username: Somedonniedude
Illinois
United States
Post Number: 594
I agree with chris, 2 cvr's on a hifonics BXi1206 would be a huge upgrade from those pyramids (and a descent overall system imo).
Username: Tpa954
Hollywood, Florida
U.S.A
Post Number: 71
Go with a Kicker ZX-750.1 Off Ebay , there not that expensive around 175 off ebay Refurbished may be a little less . There also underrated so it will probably be pushing around 1000 .
Username: Cblaze
Us
Post Number: 1037
hifonics would get a lil bit louder,the 750.1s usally only get 800-900 watts
Username: Nd4spd18
Northwest PA
Post Number: 4855
Yeah and the hifoncs will only do 900-1000. You will not notice a bifference between those, and the Kicker is 1000x better quality.
Definetly the Kicker if you can get it cheaper.
Username: Hqh17
US
ok. im gonna have to stick with my pyramids. and ive found 2 amps that might be possibilities:
1. Cadence TXA-6004 for $180
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6099
2. MA Audio HK898 for $130 (refurbished)
http://cgi.ebay.com/MA-AUDIO-HK898-1200w-2-CHANNEL-CAR-AMPLIFIER-AMP-HK-898_W0QQ itemZ270191587761QQcmdZViewItem
any advice?
Username: Hqh17
US
i know this stuff is crap but its all i can afford :/
im just trying to find the best of the crap
Username: Nd4spd18
Northwest PA
Post Number: 4874
Both of those amps are likely to be overrated. But the Cadence is without a doubt the better of the two.
Username: Nd4spd18
Northwest PA
Post Number: 4875
Wait, if you can spend $180
If you need the power at 1 ohm
http://cgi.ebay.com/ebaymotors/NEW-Hifonics-BXi-1206D-1200W-Brutus-Mono-Amp-BXi1 206D_W0QQcmdZViewItemQQcategoryZ38638QQihZ017QQitemZ270197785879QQrdZ1QQsspagena meZWDVW
If you need power at 2 ohms
http://cgi.ebay.com/KICKER-ZX750-1-CAR-AUDIO-750W-CLASS-D-AMP-AMPLIFIER_W0QQitem Z150198264427QQihZ005QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5082
sell your subs or die lol!
Illinois
United States
Post Number: 597
What are your subs voice coil configuration? I'm guessing either dual 2 or single 4 ohm judging by your 2nd post.
Username: Hqh17
US
Post Number: 7
theyre single 4 ohm
Username: Nd4spd18
Northwest PA
Post Number: 4916
Then the ZX750.1 is your amp :-)
Username: Drant19
DUB-C, TX
Post Number: 128
zx750.1 = perfect for those subs!
Username: Tpa954
Hollywood, Florida
U.S.A
Post Number: 75
Bro get rid of those subs to some one around the way that doesn't know anything about Car audio , go to one of your local Pawn shops and buy some decent used subs (Kicker CVR, CVX, Good But Cheap) and i guarantee they will tops the those two pyramids in every way possible.
Username: N2audio
Lawrence, Ks
Post Number: 1431
Scott - glad to see you sticking with your budget subs. ALMOST any sub can perform well given the right power and more importantly a good enclosure. Which model pyramids do you have?
That kicker 750.1 would be an excellent amp if you can fit it in your budget.
If not, here's a good quality refurbished lanzar optidrive that will give you 700w at 2 ohms, and 1000w at 1 ohm if you ever change subs.
http://cgi.ebay.com/LANZAR-CLASS-D-MONO-BLOCK-DIGITAL-CAR-AMP-AMPLIFIER_W0QQitemZ230206475025QQihZ013QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Hqh17
US
Post Number: 8
i have a pair of PWRD12s
any chance i could get a little more power for the money than the kicker? i was sort of looking at the Lanzar HTG264. ive heard mixed reviews about Lanzar. i was thinking the vibe 286 until i read the manual. on Lanzar's website they say it does 2 x 1000 watts rms at 4 ohms but the manual says 2 x 300 watts rms at 4 ohms. i then checked the manual for the Heritage line and the HTG264 matches what they said on the website: 2 x 600 watts rms at 4 ohms
thoughts?
Username: Nd4spd18
Northwest PA
Post Number: 5012
Those are not good either...... ya need to stop looking at crap brand amps and get something good, such as a kicker amp
Username: Hqh17
US
Post Number: 9
i read the good bad and ugly list [linked above] and in the amp section MA Audio is under the 'good' list with Alpine and Kicker and Rockford. i know this doesnt necessarily mean much but i found a MA Audio HK1398 for $180 [plus $30 shipping]
http://cgi.ebay.com/MA-AUDIO-HK1398-3200-WATT-2%2F1-CHANNEL-AMP-CAR-AMPLIFIER_W0 QQitemZ320199867261QQcmdZViewItem?IMSfp=TL071225082a11576
Username: Cblaze
Us
Post Number: 1143
well the list aint perfect,and i know ppl talk about ma audio,but i would like to see some benchtest to prove there overrated.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5091
Forget ma audio, 17V ratings isn't going to happen.
Username: Cblaze
Us
Post Number: 1144
they give you the rating for 14.4 volts to,they tell u both
Username: Hqh17
US
Post Number: 10
anyone know where i can get a manual for the HK1398? i figure if it says 1600 rms @ 2 ohms then it might do 1200? maybe?
Username: Nd4spd18
Northwest PA
Post Number: 5027
MA audio are overrated......... and yea, whoever put them in the good category is an idiot
Username: Cblaze
Us
Post Number: 1146
i aint saying there high qualitty,but im also not saying there overrated cuz i aint seen proof
Username: Buccaneersfan80
Post Number: 8
hey does anyone know anything about the Kenwood KAC-7203? im building my first new system and i have two 12' alpine type R 4ohm subs and im jus trying to find an affordable yet quality amplifier
thank you in advance
Username: Cblaze
Us
Post Number: 1147
kenwoods are not worth messing with,lowest quality of amp i ever had when i had mine,well my 3,couldnt get one to last longer than 2 days
Post Number: 10
really? what type of amp would anyone reccomend for two alpine subs
Username: Cblaze
Us
Post Number: 1148
how much money u got to spend
Post Number: 11
Username: Cblaze
Us
Post Number: 1149
dang thats a lil low,maybe somebody on here knows somethang
Post Number: 12
how much do you think i would need for an amp to power those two subs?
Username: Cblaze
Us
Post Number: 1150
are they siingle or dual voice coils
Post Number: 14
dual 4ohm
Username: Hqh17
US
Post Number: 11
thread jacker...
Username: Cblaze
Us
Post Number: 1151
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16367
Post Number: 15
if i purchase an amplifier that outputs more watts rms than my woofers can handle is it possible to decrease or increase them
Username: Cblaze
Us
Post Number: 1152
them subs can hold more than they are rated,just dont use the bass boost on the amp
Post Number: 16
does anyone kno if the Infinity Reference 1600a amp would be able to power 2 12' Alpine type R dual voice coil 4ohm woofers
Username: Cblaze
Us
Post Number: 1157
get the hifonics,thats the cheapest you are gonna find a amp for, u need 1000-15000 rms watts @ 1 ohm
Username: Cblaze
Us
Post Number: 1210
scott being poor dont make u have to buy cheap junk,i save for my stuff.i dont make much more than the minumum wage
Username: Hqh17
US
Post Number: 12
about how much power would a class A/B amp with 80 amps of fuses put out?
Username: Phuktupbasshead
Mesa, Arizona
United State...
Post Number: 700
I ESTIMATE about 800 watts... not much more, my friend (if that)
By the way, Hifonics has a pretty high THD level (in comparison to other class D amplifiers)... any suggestions for the poor guy that WON'T lead to the distruction of his subs?? He's got Pyramids, you guys... the LAST thing he needs is to give them unneccessary heat. Come on now... will the pro's please step forward?
I haven't read up on my s,h,i,t for a looooong time - but I do know you can get better than Hifonics. You need durability and efficiency in an amp. TELL ME I'M WRONG. Problem is... I couldn't tell you where to turn, because... well... I'll be the first to admit: I'm behind in the times.
As a matter of fact, check out my thread titled "replacing stolen amps" - I need an update on the best bang for my buck. I'm looking for a mono block that's 1 ohm stable (or better).
Don't worry, buddy, I'm not jacking your thread - I'll pass on any info I obtain. I promise.
Good luck by the way.
Username: Nd4spd18
Northwest PA
Post Number: 5400
For $200 I think a hifonics 1206d is the best he will be able to get
Username: Msand951
Riverside, Ca
Usa
Post Number: 22
which kicker 12in should i get with the 750.1 amp for an dual enclosed box.
Username: Hqh17
US
Post Number: 13
which should i get? i need power at 2 ohms
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?Source=googlebase&Pro ductID=16367
$219 shipped
or
http://cgi.ebay.com/MA-AUDIO-HK1398-3200-WATT-2-1-CHANNEL-AMP-CAR-AMPLIFIER_W0QQ itemZ320204526250QQcmdZViewItem
$210 shipped
or
http://cgi.ebay.com/PHOENIX-GOLD-RYVAL-V8001-1600W-CLASS-D-MONO-AMP-NEW-07_W0QQi temZ250199071281QQcmdZViewItem
$180 shipped
Username: Nd4spd18
Northwest PA
Post Number: 5430
I'd say PG, but do NOT buy it from indoaudio, they are known to be a bad seller
Username: Hqh17
US
Post Number: 14
really? their feedback rating is 98.5% positive
Username: Hqh17
US
Post Number: 15
i think ill be going with a Cadence TXA-6004
theyre CEA compliant right?
Username: Nd4spd18
Northwest PA
Post Number: 6241
Most non-mainstream companies don't use CEA
I don't think Cadence does
Username: Bnd_rulez
Phoenix, AZ
Post Number: 1517
I've never had a problem with indoaudio.
Username: Nd4spd18
Northwest PA
Post Number: 6251
Search this forum and google to say how many horror stories there are about them
Mesa, Arizona
United State...
Post Number: 713
(for what it's worth... )
I've always heard that indoaudio has a delivery time problem... I think people's package doesn't arrive on time, and they think they got jacked... and MAYBE they did... the point is: indo audio has always had a reputation for not delivering ontime or at all. (my eyes have read many complaints... never dealt with them myself)
hope that helps
Username: Yngve
Ksund, Møre og Romsdal
Norway
SoundMagus x1502,unbeatable budget amp, 1500 watt 1ohm,tested and past.
Username: Yngve
Norway
SoundMagus x1502, is the best low budget amp, whit true 1500 watt 1ohm load. This is an amp that have taken the budget buyers in Norway with storm.It is the best budget amp,guarantied
Username: Drant19
DUB-C, TX
Post Number: 345
"best budget amp,guarantied"
hard to believe from someone who can't even spell.
sorry but ivenever heard of soundmagus.
Username: Bonhamd
Northern, Michigan
Post Number: 344
http://www.pojacalo.com/soundmagus_X1502.htm
Username: Yngve
Norway
Post Number: 8
im not so familiar whit your language,sorry.
Username: Bnd_rulez
Phoenix, AZ
Post Number: 1532
I think you're doing quite well. Much better than I would be able to anyways, I give you much credit.
Username: Cblaze
Us
Post Number: 1793
i do not know how your name is spelled.but amps are rated at 1 % thd here and if u look closely on that page it says 1290 watts @ 1 ohm ..1% thd
Username: Yngve
Norway
Post Number: 11
Thanks Govmint,il try my best,hope you understand.
Cblaze,you are probably right, it is stil a very good low-budget amp. It has nice SQ, and much force, and no problem driving the Pyramid subs Scott have.
In Norway it cost 1000,- norwegian kroner.
one dollar=6 Nkroner so it wil fit in his 180Dollar budget,since it wil be cheeper in the US. Norway is a high kost land.
Username: Th3pwn3r
Post Number:...
Post Number: 6945
"i know this stuff is crap but its all i can afford :/
im just trying to find the best of the crap"
After reading this thread this was by far the best thing in it. That made me laugh :-) Are you willing to buy a used amp? If so you can get something pretty good for $180 just take a look on caraudio.com and you should be able to find something that fits your budget and is of good quality.
Username: Treez
Post Number: 277
x2... Hearing these guys talking about the best and worst crap...
Home > Message Board > Car Audio > Amplifiers > Archive through February 29, 2008 > Need a good budget amp [ « Previous ] [ Next » ]
