Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > Bass knobs..
Author Thread: Bass knobs..
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 159
lol whats wrong with using bass knob? y do they provide it with amps if its bad? jw.
Username: Imalik
SD2.5......ED9.1=Boom, New Jersey
Lord Protect...
Post Number: 566
They will help in producing a clipped signal, dont use them
IM THE REAL SLIM SHADY
Post Number: 16270
as long as you don't go crazy with it, you can use it. but if you set your gain right, there really is no need for it.
Username: Southernrebel
Monroe, Louisiana
2 DD3515s, 2...
Post Number: 5721
Some bass knobs are actually bass boost. And that can cause problems. Most people think you your bass knob will "turn it up"...which it totally the wrong way to think about it. That way of thinking is the reason people blow subs.
Personally, I would rather put an control in-line on the RCA's. Like a Hooker Audio XRBC. That way you can set your bass w/ the knob all the way up and use it to turn the bass DOWN.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 162
i thought they where used for an easy convient of turning off the subs? how could it sound good then with out the bass knob? because rite now i have the kicker zx1000.1 and i have the bass knob hooked up and my gain is set half way, and i usually turn the bass knob pass the halfway mark. if i take it off how would it still sound the same?
Username: Jtown
Team Revolution, Texas
Post Number: 1405
take off the bass knob and reset your gains properly, you will see the difference...promise:-)
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 164
lol thank you thieves u alwys help me out, without sayin slick stuff to me like sum ppl on here...haha much appreciated :-)
Post Number: 16272
especially on the kicker amps. you don't need the bass knob. it makes the bass sound muddy.
Username: Jtown
Post Number: 1409
no problem VT
Username: Nd4spd18
Northwest PA
Post Number: 4798
Listen to thives hes right on.........
Bass boost = clipping
Bass knob = the same thing as tuning up the BB on the amp
Set gain properly and don't use.
Now there are a few, not many, amp that have an external "gain" knob. This is also bad, as once you set the gain properly you don't want to increase it anymore.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 168
so i just got back in from doin it i took out bass knob, turn bass boost all the way down, and the gain is set at a lil past the halfway mark. and it does sound the same and better wit more power.
Username: Cblaze
Rock island, Tenesssee
Us
Post Number: 971
yea bass boost dont need to be on really it is usually default set at 45 hz,there really just for if u dont got your heqadunit up loud,to get more bass with less mid & highs
Username: Jtown
Post Number: 1413
I use my BB on my amp, but I don't pound my stuff, ever really..:-) so it's okay
BB on my amp is set ~1/2, but my sub control on the HU is set below half and I don't go over half on the volume. So you could use the BB, but not if you like wanging alot
Username: Nd4spd18
Northwest PA
Post Number: 4802
Turn down the BB and turn up the sub level...... it will sound a lot better. BB creates a peak at one frequency (translation: sounds bad)
Username: Jakeyplaysbass
ASU
Post Number: 2222
http://www.icixsound.com/iv/view_video.php?viewkey=c13838ff95ccfa94cebd&page=1&v iewtype=&category=mv
bass knobs pretty much do the same thing. i have mine at like 1/8th just so if i want to turn my subs off i can have the control in the front of the car.
Username: Nd4spd18
Northwest PA
Post Number: 4806
^^^^ Excellent vid, I forgot that it existed
That shows exactly what bass boost does and why it's bad.
Username: Cblaze
Us
Post Number: 981
yeah like ms said,peaks it at one frequency,once uve really what a clean signal sounds like u really hate bass boost,bass boost at 18 db's can make a sq system sound worst than a spl system imo
Username: Somedonniedude
Illinois
United States
Post Number: 592
Question here, Where should you set the sub level on a HU when setting your gains? In the middle? Is there a limit to how far it should be turned up to prevent clipping?
Username: Cblaze
Us
Post Number: 982
imo everythang should be set on flat gives you a better sound.set it on 0 and adjust the gain where it should be with a dmm
Username: Nd4spd18
Northwest PA
Post Number: 4823
I always tell people to set their gain with the sub level on the HU all the way up. That way, the only way it can go is down, and they are sure never to clip their subs.
You CAN put it in the middle, which is where I put it when setting my gains. If you do this, you have to know how far you can turn it up safely, in other words don't have it all the way up when playing bass mekanik. Not a good idea for noobs.
Username: Cblaze
Us
Post Number: 985
true
Username: Safe_cracker
Chicago, IL
US
Post Number: 3793
You Morons still haven't learned anything in all this time, guess I need to come back, lOl. Bass knobs and or bass boost is two totally different things. In most modern amps the bass knob controls the amount of gain attentuation. What this means is that turning the knob all the way down you effectively are reducing gain, all the way up it cannot go past the level of gain set on the amp itself. Now here is where bass boost comes in. Modern day amps have a pot on the amp that says bass boost usually centered at around 40hz, good for getting loud but sounds like crap, quite ghetto actually. This center frequency usually has a rolloff between 12-18db/octave, higher the number the less it effects the surrounding frequencies, more like a single band perimetric EQ. Now if you were to turn the bass boost pot down to ZERO, that is the magic number, you can still make good use out of the bass knob which will effectively control the gain from its set point. This is most usefull when you come across music with different recording properties which you could actively without having to run to the trunk control the amount output from the amp, turning your bass down on your HU is the wrong thing to do, all should be set flat anyways. To see if yours indeed controls gain, set your BB to zero, set your gain to 1/2 and plug your knob in. Turn the knob dial to 0 and turn your HU up to like 20. turning the knob up it should go from inaudible to audible, if it does, all is good. The only thing that makes it a bass knob is the knob adding the bass! Polo.. :-O
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 184
^^^thnx polo for the great explanation...thats what i thought bass knob is ment for...to turn off your bass so you dont have to run to the trunk...r have constant bass on..r even if u want to turn it down for a quick sec....but they keep saying bass knobs is bad on here...lol..
Chicago, IL
US
Post Number: 3794
The knob isn't bad, the amount of bass boost is! Go right to your amp and notice the adjustment that says bass boost, turn it to zero now you have nothing to worry about. Polo..
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 185
haha thnx yea i never had the bass boost to begin with...my gain is set alil past the middle, and the subwoofer output on my HU is set at +6.is that ok? i jus found that setting out and was playing with it and it sounded louder n powerful wen i turned it to +6.
Monroe, Louisiana
2 DD3515s, 2...
Post Number: 5733
Polo,
See post #4 :-)
Username: Torn
Post Number: 420
what about subwoofers level built min the HU?
Chicago, IL
US
Post Number: 3796
Post #4 says nothing of what I described! Input level is not gain level.... Polo..
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 187
so using the bass knob u have to have it set to whateva the amp gain is set at? u cant turn the knob all the way up?
Username: Nd4spd18
Northwest PA
Post Number: 4838
Polo you don't seem to understand that on many amps the bass knob IS a bass boost control. On others it is a gain control.
In either case you don't need it, and in the first case it's very bad.
I stand by everything I said here 100% as well as what jake papa and Canaan posted.
Username: Nd4spd18
Northwest PA
Post Number: 4839
VT: If you want to turn you bass down/off turn your HUs sub level down/off. Thats what it's for.......
Username: Jtown
Post Number: 1416
I still use my BB on my amp, but I am very careful with it:-) as I said before I never go past half on anything really...so long as the BB isn't cranked up and you aren't jammin all day long, you will be fine....
on the other hand, I will give the proper way a try, with the DMM and all, instead of just playing conservative and somewhat by the ear:-)
Username: Torn
Post Number: 421
AGAin:
what about subwoofers level built in the HU?
Username: Nd4spd18
Northwest PA
Post Number: 4841
Thieves: Do try setting your gain right, get rid of bass boost, and increase your sub level if you need to make it louder. I guarantee your bass SQ will sound 3x better with a flat frequency response. Bass boost does the opposite, creates a peak, exactly the same thing that most bandpass boxes do.
Torn:
As I said above " I always tell people to set their gain with the sub level on the HU all the way up. That way, the only way it can go is down, and they are sure never to clip their subs.
You CAN put it in the middle, which is where I put it when setting my gains. If you do this, you have to know how far you can turn it up safely, in other words don't have it all the way up when playing bass mekanik. Not a good idea for noobs. " If you do put it in the middle and set the gain, you can turn it up on songs that are not bass intense. Just don't turn it up and blast the latest bass mekanik CD..... good way to clip your subs.
HU sub level does not equal bass boost.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 202
"HU sub level does not equal bass boost."
what do u mean by that M.S.? like dont go crazy with it?
Username: Jtown
Post Number: 1426
BB causes a peak like he said and is more likely to clip your amp and subs. the subwoofer control on the HU does increase the strength of the signal but not as significantly as the BB does. So you are better off using the HU sub level control rather than the BB but stilll need to be careful if you set your gains with the sub level ~1/2
Username: Nd4spd18
Northwest PA
Post Number: 4846
^^^^ yes exactly
The sub level control on the HU is pretty much a volume control for the subs. It increases and decreases the level of all bass frequencies.
Bass boost creates a peak at one frequency, and by doing so actually makes other frequencies sound quieter.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 204
aight gotcha. thanks alot guys.
Username: Nd4spd18
Northwest PA
Post Number: 4849
Now on some amps the remote control has the same effect as the HU sub level....... but not many.
It's usually a bass boost control.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 206
do u think the kicker zx1000.1 is like that? this is what it says in the kicker amp manual-
RemoteBass(level control) with the remoe bass level control you have the ability to control the level of the subwoofers remotely by controlling the output level of one or more ZX series amps.
Username: Nd4spd18
Northwest PA
Post Number: 4850
That may actually be a volume level control....... do the subs turn off when you turn it all the way down? If so then it is.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 209
yea the sub shuts completely off, no bass at all...das y i was wondering whats wrong with using it, i just thought it was a convient to have it...
Username: Marcooo
Post Number: 159
Anyone know if Sundown's bass knobs control gain or BB? I'll test it tomorrow, but wanted to see if anyone here knew first.
Username: Imi4tth3w
San Antonio, Texas
Post Number: 135
that wave thing is awesome are those things pretty cheap and where could i get one? or should i just go see if i could go to a local audio shop and borrow one or something. cause i'm pretty sure my sub needs that bad. unless it just always sounds like sh!t haha. supid 15" L5..
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 218
what wave thing? lol ur talkin about the DMM(digital multi meter)? lol
Username: Imi4tth3w
San Antonio, Texas
Post Number: 137
whatever that thing that displays the waves of the subs
Username: Jtown
Post Number: 1429
Mark, I think the sundowns may be a volume control rather than a BB control, I have an RD, which is virtually identical and when I tested out my remote knob, when it was on max it was playing at the levels I had set the amp to before I plugged the knob in.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 227
so i take it kicker amp is the same way for the bass knob? because this is what it says in the manual....
Remote Bass Level Control: The Remote Bass Level Control lets you adjust the output level of the amplifier from anywhere in the vehicle.
Username: Nd4spd18
Northwest PA
Post Number: 4863
Yeah VT it sounds like yours is a level control not a bass boost. Which means it is safe to use, but the HUs sub level control does the same thing, so the knob is unnecessary.
"that wave thing" = an oscilloscope
Don't take offense to this, but if ya don't even know what its called, you not going to be able to use one effectively.
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 229
^^lmao on the second part you said, i read it and i was like WTF wus that dude talkin about wave thing? and then i realize he was talkin about that video, and i told him DMM thats what i thought it was like a high tech kind lmao...
Username: Marcooo
Post Number: 161
Looks like I'll be putting in a bass knob or 2, sub and speaker amp, tomorrow then :-)
Username: Jtown
Post Number: 1435
I said may be, don't take my word as fact. you might just wanna call sundownz and make sure.
it is really best if you use your HU for sub controls...:-(
Username: Marcooo
Post Number: 163
Lol I'm still going to test it. I always have my HU sub control set at 0, unless I want to show off for a sec or two, I just like the way bass knobs look lol.
I'll e-mail Jacob since I got a question for him anyways, just to be safe lol.
Username: Mesodumm
Tri-City, Az
Usa
Post Number: 214
I use a bass knob, I set my amp so even with knob full it doesn't distort, I like being able to adjust my bass from my seat.
Username: Marcooo
Post Number: 164
Just e-mailed Jacob at Sundown and he said the bass knob acts as a volume control for where you set the gain... so now I'm off to put it in lol.
Username: Jtown
Post Number: 1459
that's what I thought:-)
Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > Bass knobs.. [ « Previous ] [ Next » ]
