Thread: Whats better? 2x12" or 1x15" |
Bronze Member Username: Rellikfl
New Port Richey,
FL
Post Number: 15 Registered: Dec-07
| Posted on Friday, December 21, 2007 - 07:52 pm: |
What has a better sound quality/loud ratio? 2 12's or 1 15"? |
Gold Member Username: •cam•
BC
Post Number: 1361 Registered: Nov-06
| Posted on Friday, December 21, 2007 - 07:55 pm: |
Depends on subs/box. |
Gold Member Username: Loudon
Post Number: 2114 Registered: Jun-04
onces again ideally most people will say that 2 12s power and enclosed properly will be louder due to the amount of surface area being large then that of a 15 inch woofer, but it also depends on the subs been compared for instance a pair of kicker cvr 12's aren't going to be louder then a fi btl ... specify what ur looking for... itll make it alot easier to help you out bud |
New Port Richey,
FL
Post Number: 17 Registered: Dec-07
Im looking for a clean yet loud sound btw. |
New Port Richey,
FL
Post Number: 18 Registered: Dec-07
| Posted on Friday, December 21, 2007 - 07:57 pm: |
I dont know as far as brands. Im just looking for a good quality clear sound that is loud. Which of the two would be better for that? |
BC
Post Number: 1362 Registered: Nov-06
| Posted on Friday, December 21, 2007 - 07:58 pm: |
/vehicle. |
Post Number: 2116 Registered: Jun-04
| Posted on Friday, December 21, 2007 - 08:01 pm: |
well it says in ur profile u have a Ford Taurus, which has a huge trunk in it depending on ur subs an ideal tuning would be somewhere around the 32hz range ... which makes the woofer able to excel at different types of music. sealed well youd have to make the box the size that company recommends for their woofers |
New Port Richey,
FL
Post Number: 21 Registered: Dec-07
ford taurus |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 4760 Registered: Jul-06
| Posted on Friday, December 21, 2007 - 08:14 pm: |
2 12s > 1 15" on the same power |
New Port Richey,
FL
Post Number: 24 Registered: Dec-07
| Posted on Friday, December 21, 2007 - 08:15 pm: |
Thanks M.S. |
Gold Member Username: Jkidder
Gunshine ,
State
Flawda
Post Number: 2950 Registered: Nov-05
| Posted on Saturday, December 22, 2007 - 04:44 pm: |
what year? |
Silver Member Username: Tips
Post Number: 223 Registered: Jan-05
| Posted on Saturday, December 22, 2007 - 05:02 pm: |
wouldn't it also depend on they type of music you listen to? if you only listen to rap music. wouldnt a 15 be able to hit the notes lower than 2 12s? |
Silver Member Username: Gh0st_31
USF,
FL
Post Number: 644 Registered: May-06
| Posted on Saturday, December 22, 2007 - 05:29 pm: |
2 12s would be louder in a properly made box but I always like single sub setups more. only 2 more db louder for twice the price. plus i like to look of just 1  |
Northwest PA
Post Number: 4804 Registered: Jul-06
| Posted on Saturday, December 22, 2007 - 05:40 pm: |
That's a myth......... 2 12"s should be louder than 1 15" even on the low end. |
Gold Member Username: Frkkevin
¤ Resonant Engineering...,
¤ Fort Worth...
Email
Post Number: 4360 Registered: Nov-05
| Posted on Saturday, December 22, 2007 - 05:43 pm: |
all depends on a lot of variables.. sound displacement for 2 12s is not a whole lotter greater than 1 15 |
Silver Member Username: Cblaze
Rock island,
Tenesssee
Us
Post Number: 987 Registered: Sep-07
| Posted on Saturday, December 22, 2007 - 08:44 pm: |
not much diff,i would just go with what you want |
