Home > Message Board > Car Audio > Head Units > Archive through March 16, 2004 > Pioneer 8500 Head Unit
Author Thread: Pioneer 8500 Head Unit
Patrick W.
Do you think that the Pioneer 8500 is worth the money or should I go with the 7500?
Patrick W.
And also are there any other head units that you would recommend instead of that in the same price range that are just as good or better?
dude the 8500 sucks you should go with something else that head unit is a waist of money
INCUBUS
I think that the 8500 is a good unit. But i thiink you should check out the Panasonic CQ-DFX983U I just put one in my G/F's car and its amazing. The 5v preouts are sweet. Just check it out it might not be you taste but its worth a look.
los
na man the 8500 is basically the same as the 7500 and like $100 less . u can even go down to the 5500 prctley the same just the display is not as sweet as 7500 n at around $160 its ot bad
Username: Sralcharger
i own a Deh-p750 and it's ok but not the best once again. it's all about what that person wants. who is ever reading this buy what u want to but get facts get what ever then buy what u want to buy thats the bottom line becase stone cold said SO.
donCapi
Hi,
I have a KEH-7025 and the face is faulty. Doesnt display anything anymore just blinks. CAnt get my hand on a new one or a used one anywhere. Help!!
Home > Message Board > Car Audio > Head Units > Archive through March 16, 2004 > Pioneer 8500 Head Unit [ « Previous ] [ Next » ]
