Home > Message Board > Car Audio > Multimedia Systems > 7 inches TFT LCD wide VIEW screen Ca...
Author Thread: 7 inches TFT LCD wide VIEW screen Car portable DVD player
Username: Joelqin
Post Number: 24
This portable DVD player includes a rechargeable battery pack enabling 2 hours continuous play time.You can also plug it directly to your cigarette lighter for in car use.
It's Sleek, Simple to use and Powerful. This portable entertainment system allows you to view your favourite DVDs or CDs on the go. Compatible DIVX player, capable of playing most DVDs and CDs, including MP3, MP4, VCD, DIVX and JPEG files, DVD player enables you to view pictures and movies and listen to CDs, all with the one unit.
LCD display with superior video quality, built-in surround sound effect stereo speakers, with Dolby Digital decoding and anti shock suspension for those restless kids.
Exclusive design, super slim unit, plug in CAR
Support SD/MMC/MS card, with USB port & divx function
7 inches high resolution TFT LCD wide VIEW screen(16:9)
Compatible DVD,DIVX,VCD,SVCD,DVCD,CD,CD-R/RW,MP3,MP4,JPEG
Super electronic anti-shock function
Built-in double tracks stereo speakers
With coaxial output can be connected 5.1 channel
Audio-video input/output function
Full TV system: PAL/NTSC
Built-in lithium rechargeable battery and using inside the unit
Power adaptor (AC INPUT:110V-240V;DC OUTPUT 9V)
Unit size:181mm x 166mm x 38mm
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Multimedia Systems > 7 inches TFT LCD wide VIEW screen Ca... [ « Previous ] [ Next » ]
