Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > The swap RE XXX --> SS XXX
Author Thread: The swap RE XXX --> SS XXX
Username: Frkkevin
¤ Resonant Engineering..., ¤ Fort Worth...
Email
Post Number: 4320
Thinking about trading my RE XXX 15" for an SS XXX 15" .. not sure if I want to.. idk what I'd power the SS XXX 15" with but it sure would go nice in that CRX build I plan next year
What do you guys think :-)
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1858
SS = ?????
It's not Soundsplinter is it?
Username: Frkkevin
Email
Post Number: 4321
SoundStream XXX 15"
8,500RMS
-apem
Post Number: 16166
i like those subs. i got to see a pair of those at a comp last year and they hit.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1859
Gotcha...I was wondering.
I am not sure exactly what you are looking for, but if it were me I would not do it. Without knowing anything about SoundStream, I am going to have to assume the SQ will be pretty awful. Not to mention the fact that the RE is one of the best subs out there. Just my opinion.
How much will the SS cost? Would you run it at 8000RMS? That's a hell of an amp and charging system.
-apem
Post Number: 16167
yeah but he said he will be using that in a crx spl vehicle. the re xxx is hardly a spl sub.
Username: Frkkevin
Email
Post Number: 4322
it would be an even swap.. my re xxx for a ss xxx w/warranty
this would be for an spl car build next year.. or i can continue my sq car with my re xxx
-apem
Post Number: 16168
btw kevin, most of the crx guys use 10s or 12s. you gotta get it below that window line.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1860
I missed that part. Well for SPL, that would be a good sub I would imagine.
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 529
I am sorry, I don't feel anything that is built by power acoustic (parent company to soundstream) can keep up with the XXX. I have not played with the SoundStream, but I have the feeling it is a bad move.
Username: Killerzracing71
Fredericksburg, Virginia
United states
Post Number: 1788
sumone tried to argue with me tha Soundstream was better than the RE XXX too..... i want more opions
Username: Hdubb
Team Revolution
Post Number: 3224
i believe they use a 4hp motor....ill look into that but i know you can mount a ss xxx basket on a 4hp motor....
Username: Frkkevin
Email
Post Number: 4323
they do use a 4hp motor... the sub itself motor/basket look very similar to a tc
Username: Hdubb
Team Revolution
Post Number: 3225
imo id go for it
Username: Jakeyplaysbass
ASU
Post Number: 2217
ive also heard a soundstream XXX 18 ported for spl on like 6kw. they are extremely loud. it was in a smaller suv that looked similar to a ford escape, but was a foreign brand.
as far as the trade, the subs are really not in the same category saying ones an all out SPL sub and ones sq/sql. but do whatever you thinks best for you.
Username: Adddisorder
Palm Beach, Florida
Post Number: 5651
i would hold out, something could come up in a year and you may not have the money for the car and stuff like that so atleast stick with a sub that should sell easy or that you can already use. plus you may change your mind for a spl sub in a years time anyway.
Username: Frkkevin
Email
Post Number: 4329
well unless my income tax return blows i should have the cash..
i guess ill just go with a single 12" when we get the REX .. ima pick up another DD M1 so i can strap the two and be in pro 0-400 and still be running 3000-4000rms for a burp.. unless i wire under 1 ohm then itll be more power ftw :-)
-apem
Post Number: 16184
go for 2 10s with the rex.
Username: Th3pwn3r
Post Number:...
Post Number: 6337
2 9910Zs :-)
Or maybe some 10'' Atomics.
OR! Maybe some RD 10''s.
Username: Rovin
4 10 Pioneer...
Post Number: 12617
have heard that SS XXX quite a few times - sounds quite good for a spl sub ...a guy has 1 in a older model sentra & the box for it has to be HUGE though & that sub requires a sh1t load of power to get it to really perform ...he has hit 145 on iasca meter with it tuned around 35hz & box about 7cuft with 2 big slot ports on each side of the box firing into the cabin ...did some good excursion too
RE XXX IMO is a much cleaner soundind quality sub which still gets loud ....i like more quality than spl so if were me id keep the RE .....
Username: Insearchofbass
Post Number: 7394
Ive seen an install using a 15 somewhere on the internet but it was in a cylindrical tube and yes it was spl focused
Post Number: 7395
and under the window line (im pretty sure)
Username: Rovin
4 10 Pioneer...
Post Number: 12618
guy i was talking about well here is a pic of his set
Upload .....
Username: Visitor
Middleofnowhere, Minnesota
Post Number: 143
nope. not a 4hp. (100% sure of that. trust me.. i have had both:-)) its larger. (500 oz ferrite to the 4hp's 400 oz) i have had the ss xxx.. it was loud. it uses a 4" coil. cone folded though. the sub is.. fairly capable, BUT ss's customer service is SEVERLY lacking. hth.
Username: Discountaudiodirectcom
Ivins, Ut
Usa
I have been reading alot of forums of customers having a hard time finding a place to buy RE AUDIO and ATOMIC if you need anything i sell it
discountaudiodirect.com(under construction) best to call for help or orders
Thanks
Ivins, Ut
Usa
If you are looking for a Comp sub then MT is the best bet but you need to know alot about custom boxes or else it will not sound good it is used for custom comp systems very very loud if done right....if your looking for a killer loud sub for everyday use and mega bass then the REXXX is the way to go ......ATOMIC makes some Killer Subs as well
Username: Frkkevin
Email
Post Number: 4355
i have the RE XXX.. and theres nothing megabass about it :-) .. my RE SX got louder.. it does what the sub was designed for.. get low and sound great.. just not loud enough
Username: Basssquared
Kansas
Post Number: 1733
Travis got PWNED lmfao haha just jk bud oh and welcome to the Forum and yeah Kevin glad to hear my SX can get louder than your xxx ;) but i know yours sounds ten times nicer.
Username: Frkkevin
Email
Post Number: 4356
ill meter it next month.. im going to say 145-146dB at like 40hz or so
Kansas
Post Number: 1734
What numbers did your SX put up?
Username: Frkkevin
Email
Post Number: 4359
146.3 @ 42hz for 1 on one RE 35.1
151.6 @ 49hz for 2 on two RE 35.1s
Kansas
Post Number: 1736
nice scores what size box for both the single and dual sx's???
Ivins, Ut
Usa
I dont know man...the XXX is a much better sub but again thats what I think
Ivins, Ut
Usa
both subs are very nice hard to choose for me but I like the XXX. But yes they are dif.sounding
Username: Frkkevin
Email
Post Number: 4361
neither the xxx or sx is better than one another yet they are better at doing one thing over the other and vice versa
ray.. single was 4.0^3ft @ 35hz and the dual was 5.4^3ft @ 40hz .. measurements are after displacement of port/sub(s)
Kansas
Post Number: 1737
i just got my box designed today and its gonna be 3.5^3ft@34hz
Username: Frkkevin
Email
Post Number: 4362
i hope you did not pay to get it designed :-)
Kansas
Post Number: 1739
no lol no one wanted to help me on this forum :-( so i went to CA.com and Galacticmonkey helped me desing it and then i tweaked it a lil. He's the same guy that had the 4 18" btls in the clam shell with the videos on ROE.
Username: Frkkevin
Email
Post Number: 4363
Kansas
Post Number: 1740
that looks so badass too bad the seats in my new car don't fold down :-(
Username: Naledge503
Http://com4.runboard.c...
Post Number: 2485
uhhhh....galacticmonkey didnt even do his own install....his parents paid for it if I recall right. Not sayin that he doesnt know some sh!t, but I'm just sayin.....
Username: Safe_cracker
Chicago, IL
US
Post Number: 3795
Hmmm, sub looks familiar ;) Polo..
Kansas
Post Number: 1742
what sub are you referring to Polo?
Username: Frkkevin
Email
Post Number: 4364
one of those SXs.. bought it from him :-) .. subs are way under-rated.. on the proper charger they can handle a lot of power daily.. polo ran that one on 2500rms..
of course those are the old models.. you can tell the new ones from the old ones by a small SX logo on the bottom of the dustcap.. mine didn't have that
ray.. you never asked me for help?
Username: Frkkevin
Email
Post Number: 4365
btw raymond.. get on aim/yahoo so i can over-look the design
Username: 420alldaylong
Post Number: 3042
http://www.soundstream.com/subwoofers-xxx.htm
Username: Visitor
Post Number: 149
lol. gmonk is an idiot. he uses the re box calculator.. thats all
Kansas
Post Number: 1744
yeah thats what he told me to use. Is that not that good? if not then can you help me design a box visitor you seem like you know your stuff. I asked in this forum for help and no one did i asked on CA.com for 1 minute and he helped me pretty quick
Username: Visitor
Post Number: 150
there are several good designers out there.. if he designed it for you for free.. great! i just meant i wouldnt have paid for it! sorry for the confusion!
Kansas
Post Number: 1745
oh ok ofcourse it was free. but yeah i get what your saying.
Username: Frkkevin
Email
Post Number: 4370
see.. i just offered to help and you didn't care :-(
Kansas
Post Number: 1746
i did too foo lol i hit you up on yahoo like five times and i got nothing
Username: Frkkevin
Email
Post Number: 4371
next time try leaving me some max dimensions :-)
Kansas
Post Number: 1748
well me and my friend just got done cutting the wood we should have the box done by next week thanks for the plans
Username: Frkkevin
Email
Post Number: 4380
... you cut the wood? which design?
Kansas
Post Number: 1749
turns out i remeasured the trunk and the design you made with the 22 inches of depth will fit perfect.
Username: Frkkevin
Email
Post Number: 4381
if i remembered it was 21" deep? :-)
Kansas
Post Number: 1750
lol yeah thats what i meant but the weather is so sh!tty over here as soon as it gets somewhat warm i'll start screwing it together and then paint it can't wait.
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 1500
I've never been to cold to screw lol..
Ray some pics would be nice.
Kansas
Post Number: 1752
my digital camera's batteries died so no pics :-( and there is nothing to take pics of just pieces of wood. but i will get some up later oh and Merry Christmas to everyone ;)
Home > Message Board > Car Audio > Subwoofers > Archive through December 26, 2007 > The swap RE XXX --> SS XXX [ « Previous ] [ Next » ]
