Home > Message Board > Car Audio > Multimedia Systems > HELP! Jensen VM9311TS DVD/CD Bad Disc...
Author Thread: HELP! Jensen VM9311TS DVD/CD Bad Disc Error Problem
Username: Hms7675
I have burned a double layered dvd+r with a bunch of diffrent music videos on it and every time i try and play it it will make funny sounds like its tryin to play but then it will say bad disc after a minute or so. When i put in a normal dvd then it will play and sometimes when i insert a normal cd r it will say bad disc but if i take it out and then put it back in it will play. no luck with the dvd that i burned though. i put in the code and changed the marco and it still doesnt work. does this player just not play double layered dvds or is mine messed up? HELP!
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Multimedia Systems > HELP! Jensen VM9311TS DVD/CD Bad Disc... [ « Previous ] [ Next » ]
