Thread: Components or Coaxials???... |
Bronze Member Username: Spankinurwoofers
GR,
MI
US
Post Number: 55 Registered: Nov-07
| Posted on Friday, December 07, 2007 - 04:24 pm: |
Just wondering if there is any real difference? |
GR,
MI
US
Post Number: 56 Registered: Nov-07
| Posted on Friday, December 07, 2007 - 05:25 pm: |
bump |
Bronze Member Username: Drant19
TX
Post Number: 71 Registered: Aug-07
| Posted on Friday, December 07, 2007 - 06:31 pm: |
components definately sound better and have more tuning capabilities. coaxials are mainly used for your rear stage. huge difference in sound. |
Silver Member Username: Tc_skier
Post Number: 201 Registered: Oct-06
| Posted on Friday, December 07, 2007 - 08:05 pm: |
yep, if you've got the money, definitely get components. components separate the tweeter and mid from each other. in a coaxial, they're all in one piece. components are much better. anyone who's serious about their sound goes with components. |
GR,
MI
US
Post Number: 57 Registered: Nov-07
| Posted on Friday, December 07, 2007 - 11:41 pm: |
any advice for mounting the tweeter, and where to put the crossover? I've never had components before, thanks for the input. |
Post Number: 202 Registered: Oct-06
| Posted on Friday, December 07, 2007 - 11:55 pm: |
depends how fancy you wanna get. you can mount the tweeters in the stock location where your current tweeter is. or you could mount in the a-pillar. there's tons of options. just look around a bit. the crossover is typically mounted inside the door panel. |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 900 Registered: Mar-05
| Posted on Saturday, December 08, 2007 - 10:58 am: |
It's all in the set up. Components are great, but if you're going to half do it or just want to plug and play coaxials will be a better choice. |
Silver Member Username: Marcooo
Post Number: 110 Registered: Mar-07
| Posted on Sunday, December 16, 2007 - 12:33 am: |
Just read about braxials on CDTs site... wow. They got some great sh!t over there. |
