Home > Message Board > Car Audio > Speakers > Archive through February 16, 2008 > 6.5"s...recommendations...
Author Thread: 6.5"s...recommendations...
Username: Spankinurwoofers
GR, MI
US
Post Number: 44
Looking to replace the door speakers in my car. What would be the best 6.5" speakers? and an amp to power them? all for ~$100-150? Was looking at some RF T162C's, are they decent?
GR, MI
US
Post Number: 45
bump
GR, MI
US
Post Number: 46
are the eD 6000S V2 components good? They're discounted, $95, wondering if that was a good deal or not???
Username: Adddisorder
Palm Beach, Florida
Post Number: 5554
the eD ones arnt bad i would get them over the RF though.
GR, MI
US
Post Number: 50
Any better quality speakers in the same price range???
Palm Beach, Florida
Post Number: 5560
pg rsd i dont know how they stack up against the eD though. either choice will probably be good.
Username: Tc_skier
Post Number: 200
i suggest waiting a bit more and saving some money. 150 for amp and speakers isnt gonna get you much at all. 250, at the minimum, is a much better budget to work with. most people concerned with how their car sounds will spend at least 250 between components and speakers.
Username: Bernymac
Turtles have four legs
Post Number: 3501
^^ agreed
Username: Nissankicker
Grambling, LA
Post Number: 168
Get those Premier TS-????... They are the Yellow, Kevler Coned speakers... I have 4, and I couldn't be happier... They are a 2way.
GR, MI
US
Post Number: 52
Thanks for the input. Might save up a lil bit, but then what could I get for ~$250 that would be good quality?
Might also just get those pioneers or rsd's if i find them cheap or something. And how would I power those the best? Thanks again.
Username: Mfstereo
I would buy the Polk db6500 or db6501. I own the Polk db6500 and they perform great with a clean 50 watts. They are extremely musical and I listen to everything. Use 80-100HZ xover and clean amp(alpine,rf,infinity,kenwood, or better).
You can pick em up for $125 on ebay. They'll perform reasonably off your headunit till you get an amp too.
GR, MI
US
Post Number: 53
Was just looking through woofersetc.com, and found these...
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1204
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5207
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1090
These good deals? Open to any suggestions, pretty much $250 limit at this point though. For an amp and pair of good speakers for my doors.
Also, for an amp, would it be better/worse to have a 4-channel running to 2 speakers with both sides of channels bridged? Rather than a 2-channel running to 2 speakers?
Was considering this amp, only for the price...again, open to suggestions.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=445
Sorry for all the questions, lol, trying to figure out stuff for christmas when i'll have money to spend.
GR, MI
US
Post Number: 54
bump
Username: Van_man
Boston South, MA
Post Number: 3166
Those cdt are nice. Like Mat said, Alot of ppl like the PG comps too.
This would be my choice with that budget from that store.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=593
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2857
Username: Exige
YT check your email my friend. You got some deallllllls bro.
GR, MI
US
Post Number: 64
Thanks man, that's a really good deal!
Username: Exige
You got it man!
Exige is here to hook everyone at eCoustics up! Need some high quality components? You know where to look!
Username: Madjay
St.Petersburg, Florida
i have a toyota tundra dbl cab with a eclipse cd3000 and two kicker amps one for a bridge 8
' kicker sub mounted under the back seat and the other for the door speakers.fyi the tundra has 6.5 holes i have mounted 4 kicker 6x8 for now i want to find 4 6.5 that will kick butt the kickers do a good job but with them not totally flush mounted i think the quality could be better..any sugestions on brand of 6.5 that will work?
Username: Exige
Post Number: 9
go listen to a bunch of speakers at a stereo shop...decide what sounds good to you. figure out if you like heavy midbass, bright tweeter, mellow tweeter, etc. then come back here and tell us what sounds good to you.
read through this thread though. there's decent info posted here.
also let us know stuff like budget, genres you listen to, etc
i could rifle off a bunch of names, but everybody has different ears, and every brand sounds a bit different from other brands. its best to audition and decide waht you like. i advise NOT purchasing a mainstream brand though. you typically get better sound through smaller, less well known companies.
Home > Message Board > Car Audio > Speakers > Archive through February 16, 2008 > 6.5"s...recommendations... [ « Previous ] [ Next » ]
