Thread: GAIN QUESTION AGAIN |
Bronze Member Username: Gnya96792102
Post Number: 11 Registered: Aug-07
| Posted on Monday, November 05, 2007 - 02:18 am: |
I JUST HAVE A QUICK QUESTION, I own a 200 watt peak 50 rms x2 @ 4Ohms amp that i want to hook up to my pioneer speakers 220 peak 35 rms, Will My Speakers Blow OR Will It be ok once i set my gain settings right? OH AND PLEASE DONT SEND SARCASTIC MESSAGES BEACUSE IT WILL ONLY WASTE YOUR TIME AS WELL AS MINE THANKS. (IN CASE ANYONE NOTICED I ALREADY ASKED A SIMILAR QUESTION BUT NOT ABOUT THIS AMP) |
Bronze Member Username: Drant19
TX
Post Number: 55 Registered: Aug-07
| Posted on Monday, November 05, 2007 - 10:56 am: |
if you set the gains correctly then no you wont blow your speakers. you dont have to use all of your amps power. use a DMM. |
Post Number: 12 Registered: Aug-07
| Posted on Monday, November 05, 2007 - 01:54 pm: |
What's A DMM |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 10977 Registered: Jun-06
| Posted on Sunday, November 11, 2007 - 02:26 pm: |
Digital Multi Meter. $20 at Sears. |
Post Number: 14 Registered: Aug-07
| Posted on Monday, November 12, 2007 - 05:37 am: |
I own a digital multi meter what should i test |
Gold Member Username: Carguy
Post Number: 6625 Registered: Nov-04
| Posted on Wednesday, November 14, 2007 - 04:18 pm: |
If you haven't used a DMM before, then don't bother. Instead, try this. Look at your gain/level control. It should have something like 1v on the right and 4v-8v on the left. Now get info on your HU's output voltage. If it says 4v, then set the control half way. If it's 8v (newer models), then set the control to the left. If you're not sure, and your HU is old then it's most likely 2v. So set it between middle and right. |
