Home > Message Board > Car Audio > Subwoofers > Archive through October 28, 2007 > Eclipse SW8200 and amp????
Author Thread: Eclipse SW8200 and amp????
Username: Mj23dynasty
Harrisburg star city, Pistolvania
Post Number: 10
}Sorry for the second post but this one will probably get more attention. Ok someone reccomended that I get an eclipse TI and I like eclipses but couldn't find one on ebay so what do you guys think about the eclipse SW8200 any know anyting about those?? And every1 is tellin me to get rid of my audiobahn A8000T's I was jus goin get the new model the A8000V they're a lil more flashy but same amp but which amp should I get to give me 800RMS to each sub? That's not to expensive? And another thing the box requirements are pretty big for those I have an 05 camrt you think they'll fit? But if those are good what should I get for some loud pounding sql. Becuase my 3 8" L5's and doin it for me no more there on ebay right now lol.
Username: Kyle_lowe
Post Number: 557
the a8000t is a good budget amp
it puts out its rated 800
i ran one for about a year and it never got hot
are you looking to run 2 subs, so you would need 1600 wats?
if so then check this amp saz1500d http://www.sundownaudio.com/
also if you are looking to run that muh power, you might need to upgrade your electrical system
Post Number: 23
}This is a dead post I'm going with FI BLs instead
Home > Message Board > Car Audio > Subwoofers > Archive through October 28, 2007 > Eclipse SW8200 and amp???? [ « Previous ] [ Next » ]
