Thread: Need help on front door speakers |
Silver Member Username: Torn
Post Number: 255 Registered: Jan-07
| Posted on Sunday, October 28, 2007 - 04:46 am: |
Baught some zapco front's but they are a qaurter inch too small can screw them in the stock door speaker place correctly, what can i do to make em fit? setup almost done that the only thing left basically will post up pics after completed. |
Gold Member Username: Joebruce
15 AQ HD3
Post Number: 1616 Registered: May-04
| Posted on Sunday, October 28, 2007 - 04:48 am: |
Get some spacers or somethin. What size are the Zapcos and what size doors you got? |
Post Number: 256 Registered: Jan-07
| Posted on Sunday, October 28, 2007 - 05:00 am: |
a 92 camry, the stock door speaker pod can be unbolted off, the speakers are in the garage to lazy to go down now spent all day taking apart my car and cutting new wiring and craps and yea found out the speakers dont fit right even though crutchfield says "the size fits" on the speakers they sell at their site. I think they're the i-602 model door speakers. also how would i safely bolt by sub box down in my trunk, or any kind of antitheft solution? |
15 AQ HD3
Post Number: 1617 Registered: May-04
| Posted on Sunday, October 28, 2007 - 05:08 am: |
Hmm if your fronts dont fit Id email Crutchfeild and tell them they dont fit. Maybe they will give you some spacers for free. As for your sub you can just bolt it down inside your box to the chassis of you car. |
Post Number: 257 Registered: Jan-07
| Posted on Sunday, October 28, 2007 - 05:37 am: |
oops, i meant i looked for speakers on there first, but baught the zapco's elsewhere but it is the same size as what crutchfield says that would fit my car but doesen't i gotta make em fit because it's been 2 months since i baught them can't return em anymore. Also i got the fi shirt quotes 11$ shipped only got white color and none of the collar shirts come my size lol, gonna buy 2 shirts. |
15 AQ HD3
Post Number: 1618 Registered: May-04
| Posted on Sunday, October 28, 2007 - 05:59 am: |
lol cool for the shirts! But for your speakers,what size are they? do they not fit depth wise or size wise? if they are to deep you can buy spacers and if theyre to small or big you can buy adaptors for them. |
Post Number: 259 Registered: Jan-07
| Posted on Sunday, October 28, 2007 - 07:05 am: |
ya they fit in the depht wise but qaurter inch too small, and was pissing me off hella cuzz i spent 9 hours doing the knucktkoncepts fricking ring terminals and other crap, those things where so hard to clamp down on with my clamp and crap seem like it was 24k gold + steel i had to use a hammer on it + electric tape to ensure secure to it.But any way i can get around those damn zapco speakers to fit? |
15 AQ HD3
Post Number: 1624 Registered: May-04
| Posted on Sunday, October 28, 2007 - 07:21 am: |
lol yea sometimes those crimp things dont work. But yea what size are your speakers and what size holes do you have in your doors? |
Bronze Member Username: Matt_uk
Post Number: 19 Registered: May-07
| Posted on Sunday, October 28, 2007 - 07:29 am: |
Adaptors are easy to get hold of, unscrew your old ones and replace them with new 'brackets' for your new speakers, thats how it works for us in Europe lol |
Post Number: 262 Registered: Jan-07
| Posted on Sunday, October 28, 2007 - 07:31 am: |
ok u made me go down and get the specs, lol but they the zapco i-602. on the cutout sheet it says the speakers are 6.161" (156.5 mm). hope you or anybody can help me on this install, pics be up after it's completed. |
Post Number: 263 Registered: Jan-07
| Posted on Sunday, October 28, 2007 - 07:34 am: |
also i didn't know zapco used watermarks on their cut out after seeing the cut out under the my ceiling lights while posting the other last message. |
15 AQ HD3
Post Number: 1626 Registered: May-04
| Posted on Sunday, October 28, 2007 - 07:38 am: |
Hmm 6.161 speakers? Thats odd. You might have to make your own brackets for those. Im guessing your stock speaker holes are 6.5? You might wanna check out Crutchfeild.com or call them and ask for adaptors for your speakers/car. Hope everything works out for ya tho and let me know how those Zapcos sound,Ive heard mixed reveiws about them. Oh and are they coaxials or components? |
Post Number: 264 Registered: Jan-07
| Posted on Sunday, October 28, 2007 - 08:07 am: |
i used crutchfield as a example, they said thier speaker they sell in the size same as the zapco's. so i baught the zapco's somewhere else. and they don't fit after i tried to install earlier. and the site says the same diamensions should fit to my vehichle. don't get confuesed now lol, all i need to know now is are there anyways to get these things fit? by bsaically the time i wake up? |
Silver Member Username: Kravenblood
Ohio
Hmmm
Post Number: 315 Registered: Aug-05
| Posted on Sunday, October 28, 2007 - 08:11 am: |
if you have a caraudio shop see if they have any abs plastic and make a ring if they dont goto lowes home depot buy something plexi and do it with that put deadner on either one |
Gold Member Username: Jakeyplaysbass
ASU
Post Number: 2033 Registered: Jul-05
| Posted on Sunday, October 28, 2007 - 06:50 pm: |
kevin has a pretty solid idea. tell us how those zapcos sound after you get everything hooked up. |
