Home > Message Board > Car Audio > Subwoofers > Archive through October 28, 2007 > 8 gauge speaker wire
Author Thread: 8 gauge speaker wire
Username: Cblaze
Tn
Us
Post Number: 286
name a good place to order it by the foot
Username: Frkkevin
¤ Resonant Engineering..., ¤ Fort Worth...
Email
Post Number: 3931
just use 8awg power cable.. www.knukonceptz.com will probably be the cheapest for decent wire
Username: Joebruce
15 AQ HD3
Post Number: 1612
Well you wont need 8ga speaker wire,ever really,unless your running alot of watts to your subs that are 30 ft from your amps. 12ga will be fine. Prolly more than enough. But yea go to www.knukonceptz.com for your wire. Id just get 12ga but if you must,you can get 10 or 8 ga for a lil more.
Username: Cblaze
Tn
Us
Post Number: 287
i tried that site it wont let me process my order it comes up with a coldfusion error or somethang
Home > Message Board > Car Audio > Subwoofers > Archive through October 28, 2007 > 8 gauge speaker wire [ « Previous ] [ Next » ]
