Thread: B&K |
Gold Member Username: 420alldaylong
Post Number: 2819 Registered: Sep-06
| Posted on Saturday, October 27, 2007 - 12:34 am: |
Who has been meter on a B&K and is it close to TL numbers? |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 1...
Post Number: 5411 Registered: Mar-04
| Posted on Saturday, October 27, 2007 - 01:15 am: |
If you go to a larger (Triple Pts, Regionals, or Finals) USACi Event, they sometimes have a B&K mic. As far as #'s compared to the TL, I have seen it higher and lower than the TL. From most of the people I have talked to and seen run on the B&K, its usually right on or within +0.4dB of the TL. |
Post Number: 2823 Registered: Sep-06
| Posted on Saturday, October 27, 2007 - 03:29 am: |
Anyone else |
Bronze Member Username: Kenny_coleman
Post Number: 15 Registered: Oct-07
| Posted on Saturday, October 27, 2007 - 10:06 am: |
Canaan is correct |
Silver Member Username: Zacdavis
Beloit,
Wi
Post Number: 655 Registered: Dec-03
| Posted on Saturday, October 27, 2007 - 12:08 pm: |
Until last year when it was calibrated, it was running .9 higher than the TermLab. Since the re-calibration it has been much tighter. Scores are near to and even under the TermLab. But with any transducer, temperature, humidity, and barometric pressure will manipulate the score. Although accurate, the BnK is not the most consistent sound pressure measuring device. In my opinion, the BnK "mic" should be retired and the "sensor" to use for world records should be the same used for world championships...the TermLab |
Monroe,
Louisiana
2 DD3515s, 1...
Post Number: 5412 Registered: Mar-04
| Posted on Saturday, October 27, 2007 - 12:23 pm: |
Like Zac said...the B&K can be manipulated by the environment pretty easily. I have seen it read lower than the TL at indoor shows. |
