Thread: Installing deck in 97 buick riviera |
Silver Member Username: O0airjordan120o
MN
US
Post Number: 153 Registered: Sep-07
| Posted on Friday, October 26, 2007 - 10:25 pm: |
does anybody know how? im helpin a friend and dont know how to uninstall the stock deck and cant manage to find out how to take out the dash... diagram or links would be nice |
Silver Member Username: Jnoel
AIM= j69noel,
KY
Post Number: 318 Registered: May-07
| Posted on Friday, October 26, 2007 - 10:32 pm: |
i've done it before...the whole dash pops off in one piece....find the seam of the dasy and start on a cornor you can use a small flat head screwdriver and prise real gently...dont scratch the dash....the screws for the factory head unit are behind the dash |
AIM= j69noel,
KY
Post Number: 319 Registered: May-07
hope this helps... |
MN
US
Post Number: 154 Registered: Sep-07
| Posted on Friday, October 26, 2007 - 11:40 pm: |
thanks. wherez the firewall access? how did u run your amp wire? |
AIM= j69noel,
KY
Post Number: 321 Registered: May-07
| Posted on Saturday, October 27, 2007 - 10:56 am: |
up above the gas and brake peddle and see if you can see a rubber grommet....pull it out and you should be good.....i didnt install a amp wire...i put a cd player in for a chick she didnt have any bang to go in... |
