Home > Message Board > Car Audio > Subwoofers > Archive through October 28, 2007 > Power Problem?
Author Thread: Power Problem?
Username: Noob101
Taylorsville, Utah
Post Number: 100
Lately my sub has been acting wierd like from time to time it will like all restart like for example i was driving last night and while on the highway all the lights in the car weant a little brighter then everything like restarted my headunit turned off and then turned back on and continued to play would this be a power probelm or some type of wiring problem in either case any advice to fix the problem? i have a Fi Q 12 running of a ED Nine.1
Username: Mixmastaspig
Canada, Canada
Post Number: 1179
I would say there is a loose wire as your headunit turned off. Check the power supply/ground for the headunit and ensure everything is solid and connected. If everything looks good check yoru fuses, battery terminals...etc As your amp is hooked up to your headunit so it will shut off when the headunit does.
Home > Message Board > Car Audio > Subwoofers > Archive through October 28, 2007 > Power Problem? [ « Previous ] [ Next » ]
