Home > Message Board > Car Audio > Subwoofers > Archive through October 28, 2007 > Dd 2515
Author Thread: Dd 2515
Username: Spivey17323
Dunellen, New jersey
United states
Post Number: 754
anyone had any experiences with it. my friend just ordered one
Username: 30hrtz
Raleigh, Nc
U.s.a
Post Number: 73
should be the same as my audioque 2.5 15.they hit very clean and loud.must be ported and they can easily take more than the rms rating.what vehicle is his goin in?They are very loud rear firing in a mid size suv.
United states
Post Number: 756
he has some mazda sedan. idk waht model
Username: 30hrtz
Raleigh, Nc
U.s.a
Post Number: 74
hope it has a big enuff trunk lid opening to get that 4plus cubic foot box in there.if so it surely will wang hard.my suggestion is to port a lil lower than the dd site says.they say 16sq in of port area per cuft,which is fine but go deeper than the 16 inches recommended to tune to 40hz.I went with that,i got 4 cubes net,64 inches of port opening 16 inches long.and it dose slam hard @40hz and anything between 35 and 45 hz.mine drops off at 35 and loses alot of volume so im gettin ready to build a nother box,prolly downfiring,5 cubes tuned to low 30s.on a kicker zx750.1.
Username: Nd4spd18
Northwest PA
Post Number: 3554
You can put that sub in as little as 3 cu.ft. and it will do fine.
Home > Message Board > Car Audio > Subwoofers > Archive through October 28, 2007 > Dd 2515 [ « Previous ] [ Next » ]
