Thread: Fatmat, Dynamat or edead v1???? |
Gold Member Username: Loc_out
Santa Ana,
Ca
Resonant Eng...
Post Number: 1322 Registered: Feb-05
| Posted on Thursday, October 25, 2007 - 12:49 pm: |
Okay i plan on laying one of those on my truck tired of the rather sound. Which one should i go with??? |
New member Username: Bass_enjoyer
Post Number: 9 Registered: Jun-07
| Posted on Thursday, October 25, 2007 - 04:27 pm: |
I don't know, maybe double layer the edead? Depends on if you want value or quality, check this: http://www.sounddeadenershowdown.com/conclusion/ |
Gold Member Username: Extrmndor3
Post Number: 7051 Registered: Feb-06
| Posted on Thursday, October 25, 2007 - 05:55 pm: |
dude i just went to home depot and asked for peal and seal... and they did not knew nothing about it.. so i explained what it was... they took me to the roofing sectiona nd there was some shyt called quick fix roof and gutter repair tape... it comes in a roll of 6 inches x 25 ft.... i paid 18 bucks including taxes.... and its better than the edead v1... go to home depot and ask for roof and gutter repair tape.. or quick fix |
Santa Ana,
Ca
Resonant Eng...
Post Number: 1324 Registered: Feb-05
| Posted on Thursday, October 25, 2007 - 06:00 pm: |
I work part time a lowes and i saw some yesterday. I was wondering if would work. Any specail tools??? |
Post Number: 7052 Registered: Feb-06
| Posted on Thursday, October 25, 2007 - 06:10 pm: |
no special tools manis like stickers.. u peel the backing off and it has some adhesive shyt so you just put it where u want it.. |
Gold Member Username: Frkkevin
¤ Resonant Engineering...,
¤ Fort Worth...
Email
Post Number: 3906 Registered: Nov-05
| Posted on Thursday, October 25, 2007 - 08:13 pm: |
you do need to heat it up with a heatgun.. or hairdyer.. or other source of heat .. but yea.. peal and seal is great, not quite as thick as dynamat extreme but when doubled up its thicker |
