Home > Message Board > Car Audio > Security Systems > Archive through December 29, 2007 > Intellistart 4 problems
Author Thread: Intellistart 4 problems
Username: Ukdj
Hi,
I've got a UK concept 650mkII + Dual prox + Omnisensor + window rollups + intellistart 4 + cliffnet wizard 2.20 pro.
All was working fine until I used the cliffnet wizard for the first time, now the intellistart doesn't start!
everything else appears to work ok just the intellistart refuses to play ball.
From the wizard I can see the RPM's working so tach line appears to be working and I have been able to program the RPM and it returns a PASS but it still fails to start ???
From the monitor screen the intellistart is listed as inactive and engine below idle.
I've looked high and low and found several posts with the same problems listed but never a resolution!! I've also seen posts stating that the wizard can corrupt the intellistart but again no mention of how to fix this ??
can anyone help?
Regards
ukdj
Home > Message Board > Car Audio > Security Systems > Archive through December 29, 2007 > Intellistart 4 problems [ « Previous ] [ Next » ]
