Thread: 12" or 10" Is deeper (in bass)? |
New member Username: Jjproductions
Post Number: 1 Registered: Oct-07
| Posted on Monday, October 22, 2007 - 05:24 pm: |
Hey, Ive recently got a new vehicle. Of course, with a new vehicle I need a new system. I was shopping around for some new subs. I need shallow-mount subs, as I have a truck. I was thinking the Kole MFW-10 or MFW-12 or maybe the Clarion or Power-Acoustik shallow models. Anyways, my friend recently got two 15's for his truck. The thing is, his two 15's put out about 800w RMS. The two 10's I was thinking about getting put out 1000w RMS. Will his bass still be deeper because his speakers are bigger? Or will mine still put out better because the RMS wattage is higher? Or mabybe I should go with 12's? Or heck, maybe I should not get the Kole speakers and maybe some other brand & model? Thanks. |
Gold Member Username: Logan__tille
Team Revolution
Post Number: 9015 Registered: Feb-06
| Posted on Monday, October 22, 2007 - 06:20 pm: |
The larger the size of a sub is, usually means it will produce deeper bass. BUT thats not always true. I would stay away from Power Acoustiks though. What your budget on subs? |
Post Number: 4 Registered: Oct-07
| Posted on Monday, October 22, 2007 - 06:57 pm: |
I'm thinkin $300-$400 for the subs... an extra hundred or so if I'm going to need some custom boxes. They need to fit behind the seats (I have 6", but I need the box 4-5"). Is Kole a good speaker? Which should I go with? Thanks. |
Gold Member Username: Freezeman_7
FOR SALE,
BNIB RD AUDI...
Post Number: 2025 Registered: May-06
| Posted on Monday, October 22, 2007 - 07:17 pm: |
jl makes a shallow woofer, as does pioneer premier, i had the premiers, loved em. not bad at all. u could get a 15 shallow mount premier i think. |
FOR SALE,
BNIB RD AUDI...
Post Number: 2026 Registered: May-06
| Posted on Monday, October 22, 2007 - 07:19 pm: |
i lied 12 or 10 in premier |
Post Number: 7 Registered: Oct-07
| Posted on Monday, October 22, 2007 - 07:31 pm: |
Right but about my first question... if I had 1000 RMS and he had 800 RMS, would his being bigger diameter make them louder or deeper or since mine have 200w more power will they be louder? I did look at the pioneer subs and they looked pretty nice. Dont think im looking for somthing quite as big as a 15 though. |
Post Number: 8 Registered: Oct-07
| Posted on Monday, October 22, 2007 - 07:32 pm: |
Nevermind the whole 15 part at the end, just read your other message. |
Bronze Member Username: Jjproductions
Post Number: 15 Registered: Oct-07
| Posted on Monday, October 22, 2007 - 08:34 pm: |
Bump. |
Gold Member Username: Bernymac
BME
Post Number: 3378 Registered: Sep-04
| Posted on Monday, October 22, 2007 - 08:39 pm: |
By hitting deeper you mean lower? |
FOR SALE,
BNIB RD AUDI...
Post Number: 2029 Registered: May-06
| Posted on Monday, October 22, 2007 - 09:50 pm: |
i think tahts what he means.. i dont think ur gonna get 1000wrms outta any shallow mount, cause those are MAX ratings, just look at rms. u might be able to put 1000 on 4 12 in premier shallow mounts in that case then yes it will probably be louder than ur friends 1 15 |
Platinum Member Username: Rovin
4 10 Pioneer...
Post Number: 12419 Registered: Jul-05
| Posted on Tuesday, October 23, 2007 - 12:23 am: |
other ppl who make flat\shallow subs elemental designs clarion kicker rockford jbl pioneer\premier etc..... |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5412 Registered: Jul-06
| Posted on Tuesday, October 23, 2007 - 01:21 pm: |
I like how you put (In bass) haha.Because obviously in a woman 12'' would be deeper  |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 192 Registered: Sep-07
| Posted on Tuesday, October 23, 2007 - 02:12 pm: |
^^i think that would be physically impossible... ...bad visual... |
Post Number: 16 Registered: Oct-07
| Posted on Wednesday, October 24, 2007 - 06:58 pm: |
You dont think shallow mounts can put out 1000w rms...? The two MFW-12's put out 500w rms each. If you learned how to add, maybe you would see that 500+500 = 1000. |
Gold Member Username: Naledge503
Http://com4.runboard.c...
Post Number: 2101 Registered: Jun-06
| Posted on Wednesday, October 24, 2007 - 07:02 pm: |
Wrong. Subs dont put out any rms...... |
Post Number: 17 Registered: Oct-07
| Posted on Wednesday, October 24, 2007 - 07:05 pm: |
... can handle 500w rms each. You know what Im talking about, you dont have to be a smart-a$5. |
Post Number: 2102 Registered: Jun-06
| Posted on Wednesday, October 24, 2007 - 07:10 pm: |
If you learned that subs dont put out power then I wouldnt be. |
Post Number: 2105 Registered: Jun-06
| Posted on Wednesday, October 24, 2007 - 07:26 pm: |
Hey Jeff. Dont take things so personally. Some guys will be d!cks around here, some wont. It was just my turn. you'll get used to it. Welcome to E. |
FOR SALE,
BNIB RD AUDI...
Post Number: 2049 Registered: May-06
| Posted on Wednesday, October 24, 2007 - 10:32 pm: |
i was saying SINGLE WONT ACCEPT 1000 watts. i can add there buddy, calc is doing me a world of good... |
Gold Member Username: Crayola0
2008 Nissan Versa!!,
Wisconsin
Post Number: 2161 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 11:10 am: |
go with the elemental designs |
Silver Member Username: Teamrevolution
ATLANTA,
GA
Post Number: 121 Registered: May-07
| Posted on Thursday, October 25, 2007 - 12:13 pm: |
what kind of truck was it? Because you have a truck doesnt mean you have to use a shallow mount, in most trucks 5-5.5 " mounting depth is fine. |
Post Number: 18 Registered: Oct-07
| Posted on Thursday, October 25, 2007 - 04:19 pm: |
Mazda B3000... 5-5.5" mounting depth would be fine, but I need the box to fit as well, and that means Id have to build a custom box, which I dont want to do. A friend already has two boxes for shallow mount subs that I can have, so thats what Im going to go with. Its a regular cab, not extended or crew or whatnot. |
Silver Member Username: Cblaze
Tn
Us
Post Number: 265 Registered: Sep-07
| Posted on Thursday, October 25, 2007 - 10:11 pm: |
u can get universal truck boxes for 12's and tens just about anywhere u can buy sub boxes |
